90rangerxlt
- Jan 17, 2015
- Reaction score
- 0
- Make / Model
- Ford
- Engine Size
- 2.3
- Manual
Hey, all! Just purchased a 1990 4x4 2.3 5 speed ranger and have a few check engine lights and don't know where to start at! First of all let me explain my problem. The truck when it's running will for the most part run silky smooth. It will however randomly shut off and will do this occasionally while driving. Starting the truck usually involves trying to get it to about 2.5-3k rpm so it won't immediately shut off. and for the first time to today it actually bucked on me while driving. I looked up the koeo and koer testing procedures and have quite a few codes and I just don't know where to start so hopefully someone can help. Okay, so during the KOEO test the codes that showed were 33, 41, 48, 66 (I disconnected the MAF the day prior for testing purposes so I assume thats why that is showing.) and finally 88. During the KOER test I get codes 21 and 33. So from what I'm gathering from my research is that there is more than likely an ignition problem happening am I correct on this? My temp gauge also barely reaches the first hash mark on the gauge, will code 21 (ect sensor) be causing that issue? Or is that a normal spot on rangers? I notice that the truck kind of runs rich, not surprising at least with a possible failing ECT sensor and maybe an ignition system that can't burn the fuel! Thanks for any help and knowledge y'all can pass down!
