Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 04-18-2018, 12:10 PM   #21
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
Do the Glove test and take head or gasket issue off the table, or find out that's the problem and you don't have to waste time on non-fixes
RonD is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 04-18-2018, 02:26 PM   #22
fr7
Vehicle Year: 1998
Vehicle Make: ford
Vehicle Model: ranger
fr7 is on a distinguished road
Default
The only oil leaks I can see are from the pan gasket and a little bit around the pcv valve. I'm picking up some latex gloves or balloons on my way home tonight.
So I unplug the coil pack, seal the glove around the radiator filler, plug the overflow tube, crank it and watch if the glove gets air in it right? Does the engine need to be completely cold?
I'll let you know how it goes, thanks again guys..
fr7 is offline   Reply With Quote
Old 04-18-2018, 06:23 PM   #23
rangerenthiusiast
rangerenthiusiast's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger Custom
rangerenthiusiast is on a distinguished road
Default
We’ll be watching your thread and hoping for the best. Good luck, bud.
rangerenthiusiast is offline   Reply With Quote
Old 04-19-2018, 10:00 PM   #24
fr7
Vehicle Year: 1998
Vehicle Make: ford
Default
Well after putting the 190 thermostat back and doing the glove test yesterday and again today I cannot see any air going in the glove. I had my friend crank it for about 10 seconds at the time while I watched, we almost drained the battery and nothing happened. Did this twice, different days, I made sure everything was sealed and no pressure was escaping.
Now I'm very lost. Is there a slim chance I still have a very tiny mini little microscopic air pocket and that's what is messing with Me? I'm sorry guys for being so annoying but I just feel so dumb and frustrated right now..
Old 04-20-2018, 09:35 AM   #25
ForTheLoveOfMonkeys
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger Xl/XLT - it's weird Extended Cab
I use this vehicle for: Daily Driving & Learning
My credo: You are what you do when it counts
ForTheLoveOfMonkeys is on a distinguished road
Default
Don't get discouraged. Diagnostics can be a real pain and I know how frustrating this can be. That's what the community is here for, it's not necessarily fast but for the most part it's free and effective.
Let's break this down a bit.
The problem:
You're not experiencing overheating but you see pressure buildup in the coolant reservoir system
What you've checked:
Water Pump is new
Radiator is new
Thermostat is new
Pressure test indicated system is sealed
Glove test showed no signs of exhaust gas buildup
OK so using this I'd say there are a few things to look into still.
Temp Sender: The unit on the water pump housing that detects heat of coolant exiting engine. You say you're not experiencing overheating, how sure are you of that? Are you pulling readings from OBDII to confirm or just trusting your gauge? Simple test to check for functionality.
Temp Sensor: Sensor that sends coolant temp to the computer. If you are using OBDII to pull temps, are you sure that the sensor is working properly?
Radiator Cap: I don't think it's likely since hopefully you changed rad caps after each new radiator, but if that little jerk has failed then that would explain pretty much all of your symptoms to a T. If it doesn't hold pressure properly then it could be the source of your problem.
Leaks: You didn't mention if you have seen any leaks or puddles on the ground so I had assumed you didn't. Double check every coolant line & fitting and after running the engine take a good whiff, if there is a leak you will smell it. Also a good idea to get under the car and look up at the timing cover, sometimes there's a leak from the WP or the surrounding area that goes unnoticed as it heats up and boils off before hitting the ground.
Really take a good look at the intake manifolds, make sure that they are sealed well. For leaks I'd recommend getting a UV dye off of Amazon and putting it in your coolant, run it for a day or two then pop the hood and go hunting for leaks using a black light and yellow tinted glasses. If there is a leak this will let you know when your engine bay lights up like a Jackson Pollock painting.
Blockage: Have you run any flushing through the system? Did you put any HG sealant in at any point? Is there a gurgling sound coming from your vents when the heat is on, particularly when you rev the engine?
There's a lot of things to still run down, and the cause of your issue could be related to any one or several of them in combination. It could still be a Head Gasket/Head issue that is very small and only presents itself when the engine is warm.
Sounds like you've got a unique beast of a problem, but don't stress yet, take your time and approach it methodically and you will figure it out.
ForTheLoveOfMonkeys is offline   Reply With Quote
Old 04-20-2018, 10:37 AM   #26
Vehicle Year: 1994
Vehicle Make: Ford
Default
Good deal
Remove rad cap and top up coolant in rad
Start engine
Might get a small burp of coolant when water pump starts to spin
Let it idle for a few minutes, it should not overflow
If it starts to overflow check water pumps spin direction, it is possible to install fan belts wrong and reverse the flow so water pump pumps coolant out of lower rad hose, which would cause it to flow out of open cap
Upper rad hose should stay cold at radiator end until thermostat opens and thats when coolant at the cap opening should start to warm up
Radiator is cutoff from circulation until thermostat opens, but it is not cut off from pressure, as lower hose is open which allows pressure to be transfer to radiator, but not heat.
If you are concerned about clearing air in the system, cut one of the heater hoses at high point and insert a metal coupler with two clamps
With engine cold and idling loosen one clamp on the coupler and slide hose back a bit any air will come out while coolant is circulating thru the engine.
When just coolant is coming out all air is out, tighten it back up.
It is possible you have a blockage in one of the head's cooling passages, this would cause coolant at that place to flash to steam when it got hot enough, but that would take at least 15minutes
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cooling system Matt Dalton 2.8 Liter Forum 3 02-09-2018 07:41 AM
cooling system 91 4.0 CreepyCrawler 4.0 Liter Forum 4 01-25-2014 11:53 PM
Transmission cooling lines routed wrong? BadRancher Transmissions 3 12-07-2013 01:26 PM
Cooling System ebgardner 2.9 Liter Forum 5 10-01-2007 10:41 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
