96ranger702
- May 29, 2016
- Reaction score
- 1
- Make / Model
- Ford
- Engine Size
- 4.0L
- Automatic
1996 Ranger 4.0 4x4 automatic 200k
I've had this truck for less than a year now and am ready to start getting this thing running reliably . Truck is in great condition even with high miles . No major work was done or needed to be , on the motor. Previous owner is very mechanically knowledgeable guy and took great care of it . He did the Chevy leaf spring swap and put F250 could in the front as well as a custom long travel bed cage for shocks . He liked to do some off roading as do I . Minor trails and minor rock crawling was it's main use .
My question is , what are some things I should start replacing in the motor that may be it's time since high mileage and nothing done yet ? As far as rebuilding the motor . Or some things I should plan for in the future .
2ndly is the transmission 4r44e . I know there is a trans thread but I've posted there a while back and got no feedback so I'm trying to kill 2 birds here .
I have the common overdrive flashing problem . Fors issued a TSB on this problem .
I am a mechanic as a profession right now but I'm young so no master . Mainly I just want to here if anyone's had this experience and if they would share .
I may have read everything there is to online but because of current situation just continouing research!
I just spent over 2 grand getting trans rebuilt . The TSB and OD light problem has to do with the valve body. Some have replaced solenoids and been fine . Some do a VB mod by drilling a hole in instructed spot to fix this issue .
I purchased a fully loaded VB from centralVB . it addresses the TSB issues and comes with all solenoids and separator plate and gasket . I had the shop install it as well as go through the trans and rebuild what's needed. Also replaced tourque converter .
Well it's been a week and the light has come back on as well as my check light for faulty solenoids .
The first time i have them VB they said it wasn't running right and something is wrong with it . So CentralVB sent me a 2nd one no questions asked . They are great . But now second one is installed and problem persists !
Before the rebuild , After driving truck for about 30 miles the light would flash and the only symptoms would be it would shift harder in first and second . when light wasn't flashing it would not .
Currently it's shifting great . When light comes on it still shifts great . Can't really notice of shifting hard .
So it's under a year warranty , I'm going to take it back to them , but I'm skeptical about the shop now . Anything I should ask or make sure they do ? I can't afford anything else really . Youd think after $2400 it would be fine now .
Anything helps ! Thank you guys your the best love this site .
