Parking brake cable on explorer 8.8 won't clear tire
t0x1k
9
Somerdale, NJ
3.slo
After getting sick of my 15x10s with 3" BS I went and got 6.5BS to tuck them in, but now the parking cable will hit the tire. I can't see a way to route the cable without putting an extreme bend in it.
Someone has had to come across this issue as I have seen plenty of wide tired trucks.
Truck is a manual so I NEED the parking brake and leaving it in gear is not an option some times. A brick or chock is not happening either. Also line locks won't work, not trusting them.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
6.5" is a lot of backspace...
Maybe you can remount the p-brake cable where it's attached on the end of your leaf spring's bracket to a separate custom-made bracket placed right next to it that will bring the cable closer toward the frame. Just an idea.
Staff online
Today's birthdays
Shran
April Truck of The Month
