Recommended locker
gabestalker
I have a 1996 ranger 4x4 and i'm looking to get a rear locker. I've looked around but can't seem to find the right one. If anyone has some info on a good and somewhat inexpensive locker that would be much appreciated. It would mostly be used for the occasional off road trip, nothing to crazy. And no i don't want to weld it. Thanks in advance.
FritzTKatt
4
Ohio
3.0
I'd go for a richmond lock rite. They're not too expensive and work very well. Just be careful in parking lots. Also, I'm not one that can parallel park very well to begin with, with a lock rite, there's no way. It just doesn't turn much at all.
I hear a lot that putting the locker up front helps more off road, and when in the case of an aussie or spool type, it goes away when you're in 2wd. A lock rite is there all the time. Problem with lockers up front is that you tend to break things much easier.
gabestalker
Ok thanks, I wil look into a richmond and see what happens.
FritzTKatt
4
Ohio
3.0
Beware that you will see increased tire wear, a touch less mpg, a very loud POP when it unloads at low speeds (seriously, you'll be convinced you just snapped an axle or something). You can hear it ratchet in tight turns, it won't turn as tight... just be prepared. It does still make quite a difference, starting on wet roads, light snow, mud ruts (especially a difference when you fall into a rut on the passenger side, but the driver side is on solid ground). It almost eliminates the need for 4x4 in most cases, since in most of those cases it performs better than the 2 open diffs. But then you put it in 4x4, and have 3 wheel drive, makes things really fun.
gabestalker
Thanks for all the info. I've driven with welded diff's before so i know how the turning can be and how fun it can be on wet roads or snow. Thanks again!
FritzTKatt
4
Ohio
3.0
It obviously won't be nearly as bad as a welded diff, but if you have that experience, then you should be fine. In my experience, it won't unlock when it's under heavy load. So if you floor it, there won't be any difference. But a gentle acceleration won't make you go crazy. I don't notice it at all at highway speeds because the curves aren't too tight, but over really long, light curves, it has unlocked once or twice (took a while to build up)
Bottom line is don't drive like an idiot and you won't have negative side-affects.
swynx
9
lewiston idaho
Mazda
4.0
my .02, i have a limited slip rear and a aussie in the front end, it works pretty damn well, i always just cruise around in 4 low till i need the front end then get out and lock the hubs in, it turns like dog crap, i can do a 2 point turn without it locked in, once its locked its about like a 6 point turn. also i dont get stupid stuck, the limited slip always gives up the ghost before i get so stuck the front wont pull it out.
since its not pure offroad i would look into a limited slip with extra clutches.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,822
SW Iowa
Engine Type
V8
5.0
+1
I like my rear limited slip so much I think I am going to put one in front too.
They don't work so well if you have tires hanging in the air and crazy articulation but this flatlander is a happy camper in snow and mud. :icon_thumby:
AgPete139
09/2014 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
61
Houston, TX
Engine Type
4.0L OHV
2WD / 4WD
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Dude, you sound like me. Just go and pay the $300 (new) for the Richmond Lock-Rite.
I did my install last year after messing around with the LSD. My truck is a DD in a big major city with 35" tires, and it's fine. I did not notice a drop in MPG. Definite traction. Easy & steady throttle in curves & turns is the trick.
You will get used to driving this an auto locker.
I think this is the best bang for the buck, and I have not a single regret.
It does chirp the tires or grind the locking mechanism in tight turns, but you learn to drive better and avoid those scenarios.
I have not noticed bad tire wear, but then again, my tires are already getting worn, too. Ha. From a real world perspective, yes, there should be "accelerated tire wear." But again, it's so minimal.
FritzTKatt
4
Ohio
3.0
What agpete said. I disagree with his unnoticeable tire wear, since after about 15k miles i saw that the rear tires had lost an extra 1/16". Other than that, he's 100% right.
Mac
183
C. Wisconsin
2000
199
4.0
I went with the Richmond "No-Slip" that is more DD friendly but cost quite a bit more. Used on my Winter 4x4 DD with no problems or regrets at all. Easy install, got another set for my 4x2.
Dave
FritzTKatt
4
Ohio
3.0
Same difference, it's the same principle, he won't go wrong with either.
smichaelR22
Rochester NY
Ultra4
get an Aussie hands down for lunchbox type
Made in USA just down the street from me. installed 100's- great lockers
Members online
Shran
April Truck of The Month
