bronc
- Aug 13, 2007
- Reaction score
- 2
- Location
- Calgary, AB
- Make / Model
- Ford
- Engine Size
- 4.0
- Manual
Hi, I'm wondering if anyone has figured out the differences in axle shafts between 91-94 31 spline explorer axles and 95-01 31 spline explorer axles. I know the Gen 2 has discs and Gen 1 is drums but I assumed the axle shafts themselves were the same but I figured that was wrong when I started looking into it.
For example G2 doesn't offer axle shafts for 1st gen, only 2nd. Nitro offers one Sku (per side) for 91-01 and one for 05-01. Yukon offers a Sku for 91-94 and one for 95-01. Jeff's bronco graveyard is the same as Yukon, one from 91-94 and one from 95-01. Some companies indicate a very minor difference in length between gen 1 and gen 2 but Yukon for sure have both the same length. I called all the companies except G2 I think. Yukon was the most willing to help, Nitro helped but with some ignorance, Jeff's had no clue and told me to call their manufacturer which is the same manufacturer as Yukon, go figure. Yukon's c clip eliminator kit specifies 95-01 only.
After all my discussions, it sounds like the bearings, lengths, everything like that is the same between gen 1 and 2. Yukon (regarding their c clip elim kit) figured maybe there is a difference in the bolting on the axle itself to the brakes but I am sure on this website it indicates how you can upgrade drums to discs so that bolting must be the same. In the end it was Nitro that indicated that the pilot diameter (the diameter of the raised circle on the flange, aka the diameter of the circle of the brake drum (91-95) or the disc (95-01) that would fit over the raised portion of the axle flange) is the only difference. The gen 1 had a larger pilot diameter than the gen 2. Hence why Nitro has their Skus in that fashion. A gen 1 axle shaft would work on a gen 2 with a little extra room between the disc (not great as you'd then rely on the studs to centre the disc) and the pilot but a gen 2 axle will not work on a gen 1. The drum wouldn't fit onto the shaft.
Has anyone else found this? I feel like this is something that should be put in the Tech Article for the 8.8.
Also, because of this the c clip elim won't work on a gen 1 unfortunately. It is the only way to get 4340 chromoly shafts. The 1541H alloy that all the other aftermarket shafts are made of are still about a 25% increase in strength over stock. This also does not jive with information implied on the page about c clip eliminators as it states that they work with drums. None that I have seen work with drums other than Strange has some for Drum's but specifically states passenger car (mustang) only.
I looked into all this because I was confused why each manufacturer was doing it a little difference and wanted to make sure I was buying the right thing. Something wasn't adding up to me.
Comments? Next time I'm at the junkyard I want to bring a caliper and measure the pilot differences to confirm.
