88mudder
- Aug 26, 2007
- Reaction score
- 0
- Age
- 34
- Location
- waterford michigan
- Make / Model
- Ford
I have a Ford AOD out of a 1990 fullsize bronco that i used in my v8 swap in a 84 Ranger. It wont upshift out of 1st gear. Tried setting the TV pressure. Found 1 port on each side of the trans. With the gage hooked on and trans in park and neutral it will peg out the gage passed 100psi. Hooked the gage on the other port and it pegs out passed 100psi in park but in Neutral is shows 0 psi. Pulled on the kickdown cable and no readings changed on the gage. The only reading where it changed is when the trans is shifted from Park to Drive, the PSI goes down.
Any ideas here?
Which port is the one to use, drivers side or passenger?
Any ideas here?
