MIke713
- Apr 3, 2008
- Reaction score
- 0
- Age
- 65
- Make / Model
- Ford
- Automatic
Hi Picked up a 2006 Ranger with the 3.0 l v6 133,000 on the clock check engine light is on , pulled codes po300,po301,po302 and po316 , truck has new plugs( autolite double platinums and a new coil pack , all plug wires are right , plugs are white and not wet when I pulled them. CHecked intake for any vaccum leaks with propane no change , no antifreeze in oil and radiator not low( losing and coolant) need to figure this problem out any leads would be appreciated.
I plan on replacing the plugs with Motorcraft plugs as I feel the autolites are not as good, also new wires and I am gonna have the coil pack checked out .
thanks in advance, Mike
