4cyl 2.3l ranger upgrades
flaminranger
washington (the state)
2.0
I don't know about 17 lbs injectors but 5.o mustangs and a lot of trucks have 19lbs injectors.
I can't remember what color the injector tops are for 19lbs I think they are tan on top 24lbs are light blue and 30 lbs are red.
You can go to the autoparts store and see if they have any ford 19lb injectors to see the color.
red85
7
Kitchener, Ontario, CANADA
306 ci
19# injectors are orange top. 24# are blue. 14# are grey.
Snal
Sacramento
swap in a 5.0. problem solved :icon_thumby:
Jesse187
I'm looking at doing some mods to my 96 2.3l 2wd as well. I was thinking about a pair of those Accel coil packs. Maybe them, an intake, and those 19# injectors? I'm on a tight budget. Want some bang for what little bucks I have. And my ride only has 106,000. Its a baby. lol
three8_doob
2.3l ranger uprades
I put cold air intake, straight piped the exaust with a flowmaster and blocked off egr valve and got lots mor bottom end but still has hesitation off the line prob need high flow cat but can light em up with 235/75/r15 tires on
debogus
Beauklahoma,peoples republic of Kommiefornia
2.3
the truck may be old but only has 82000 on it.
Um???
All yours ?
MY 93 dosent have a hundred thou digit on the OD so it only has 40 thou on it according to the smog check guy :thefinger:
But I know that I have turned it over three times and put a used motor/ tranny in it 10 thousand ago .
three8_doob
this isnt about what you guys are talking about but i have a 1994 ranger 2.3L 2wd and my throttle cable broke i checked all the part stores and the ford dealership and they said they dont make them anymore and was wondering if there is a throttle cable from another vehicle i can use.
thanks in advance
NIPs
Michigan
FORD
2.5L 4Cyl
One shot one Kill
a cold air intake is useless, unless u port and polish ur heads, and increase the size of ur exhaust
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Well, even though the original thread was 6 years old there is probably a ton of good information here...but it gets asked quite a bit...haven't had many lately but a few years ago it was asked at least once a week...
I replaced the 2.0 head (not block) and had a shop install a better cam...they also shaved the head and did the valves and I did my own P&P...
It was so peppy and I was extremely happy with the results...until I overheated it and cracked the head...
Then I learned a very valuable lesson about cooling systems and how not to let them go unchecked...
About $2,000 too late...but wow what a difference a cam and a bit of grinding can make...
