Should I be picky and only go for a 90' BII or settle for an 87-89?
SSSnakeCharmer
Alright so I'm looking to buy a BII really soon and I'm having a hard time deciding on whether or not I should only buy a clean 90' or if I should settle for a clean 87'-89'. I'm leaning towards getting a 90' but a few things might change my mind.
1. Do all 90' BIIs come with the D35 instead of the D28?
2. Do all 90' manual BIIs have the M5OD or were some made with one of the other MT transmission models? How can you tell which one it has? Vin?
3. Do 90's only come with push button 4x4 or are there some with manually engaged 4x4? Do both variants have manual locking hubs? What is better push button or manual?
4. Is it worth it to wait for the perfect 90' or should I settle for an 87-89 and do the D35 and M5OD swap?
5. If at some point I decide to SAS swap and use a D44 will any of it even matter? Will the M5OD work with the D44 and SAS setup?
Sorry for the long wall of text. Help me out lol!
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I wouldn't wait around if you find a nice one that is a little older. The axle swap is easy, and bolt on. You might even score a 95-97 axle with the better front brakes while looking for swap parts.
Few BIIs were ever built with the M5OD, most had an FM146, so you will be swapping that anyway.
Push button 4x4 seemed a bit more common on them than the manual, but it could come with either. I prefer the manual system because it's much easier and you know it's going to work.
SSSnakeCharmer
Thank you! I'll keep all of this in mind! One more thing, how do I figure out what transmission is in it? I read somewhere that M code is the M5OD but I'm not sure what M code is referring to? The vin? Or is there a sticker on the door with the trans code? Pics would help a lot.
RonD
Official TRS AI
TRS Technical Advisor
8,367
canada
SSSnakeCharmer
Ok so if I see a B2 with an M code on the sticker it has the M5OD?
Kayakcrazy
Eastern nc
2.9
I wouldn't wait around either. Waiting for the perfect one is probably futile. If you find one with a nice clean body and frame I'd jump. The reality is if or when you start your build a lot of the stock parts will be swapped out for others anyway. While those heavier stock pieces are good there are even better options out there. Also with all the flack the stock drivetrain gets its not bad. If you keep the tires small and drive with some sense you would be amazed at what the little B2 can do and hold up reasonably well.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Build date after 11/89. It will have the M50D and D35. I had one. Still have the tranny and D35. I bought it without knowing. Good luck on finding one.
redhurricane
RBV's on Boost
3
Westminster, Colorado
2.3
88-up will have the newer dash/cluster versus the 83-87 metal dash. Other interior features will be different on the 88-up versus 87-down. I preferred the old dash.
typically, the 83-87 will also have the 1350 manual transfer case and not push button 4wd.
Find the cleanest shell regardless of year, the running gear is easily swapped and still available at the junkyards from multiple donor vehicles.
wildbill23c
TRS Banner 2012-2015
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
What I've ran across lately is you either find one with a great body and interior but the drive train is shot, or you find one that's beat to crap but a good drive train...I guess you don't get both in the same vehicle LOL. If you happen to find one with both good drive train and good body, the price is high enough to make you run away. I've found a couple with both in great condition but the $7k+ asking price was completely outrageous.
SenorNoob
543
Middle Tennessee
Engine Type
4.0
2WD / 4WD
1.5" Front + 4" Rear
245-70-R16
88-up will have the newer dash/cluster versus the 83-87 metal dash. ...
Find the cleanest shell regardless of year...
1st. So the B2 is different from the Ranger? Cause every '88 I've seen is the "old" style dash.
2nd. Yes. Clean is what you want. Especially if you're going to mod it anyway..
Edit: HOLY CARP! $7k for a B2? That's beyond insane. I can't even see any mods that would make that worthwhile..
Kayakcrazy
Eastern nc
2.9
7k!!!!
I have a B2 for sale then!! that would double what I have invested.
some folks are crazy, I ran across a few of those, dealers mainly trying to convince someone it was a collectable classic. Partially true but not quite there yet.
Slammin Sam
4
Western Colorado
2.9
New style dash didn't happen until 89. 84 thru 88 had the same dash. Problem with a lot of the outrageous prices is the NADA value. While searching for my current 89, I checked quite a few really clean B2s with 6K plus price tags. Sellers said "thats NADA value." My response, sell it to NADA!
redhurricane
RBV's on Boost
3
2.3
my bad, you are correct 89-up is the interior with the plastic dash (BII and Ranger) no sure what I was thinking. BOTH my builds have been 1987 vehicles, with numerous items swapped in from later model rangers and explorers.
SSSnakeCharmer
I wanted a really clean b2 but ran into the price wall. The really nice ones were all 5k+
Slammin Sam
4
Western Colorado
2.9
You have to decide how bad you want one and what you can live with. Here in western Colorado, rust isn't a problem, but the sun burns the paint off, especially the clear coat. There are many decent running rust free examples that need paint. With 2 to 3,000 for a decent paint job, that $1,000 B2 turns into a $5,000 B2 real quick. I bought my 89 from the original owner in Oct. 2013. I found it in Salt Lake City, about 5 hours from my home. During my 8 month search I drove to Denver and all the way to Pocatello , ID trying to find the right one. I was ready to give up when I found my 89 on Craigslist. 140K miles, one owner, always garaged, original paint, 5 speed, a/c, every receipt since new including the window sticker. I paid $2,300. It needed tires, but just about everything I looked at needed tires. It took 8 months and over 2000 miles to find it. Keep looking, they are out there. Good luck.
Members online
Shran
April Truck of The Month
