Need help finding what plugs into this. 00 OHV 4.0 V6
BaconSammich
2000 Ford Ranger 4.0L V6 OHV.
I had the valley pan gasket coolant leak and stripped it down to the block. Put it back together and have 1 electrical connection left?
Its attached to the wiring harness right by the coil pack plug, it is small and is only an inch or so long. What goes into this and where does it come from?
Thanks!
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
RFI capacitor. The original one will by a small cylinder. If it was replaced it may be a squareish unit. If it is lost go to the junk yard and rob one from any Ford you can find, they are all the same.
It should be screwed down under one of the coil bolts but I don't see it in your picture.
Members online
Shran
April Truck of The Month
