1354 Electric to 1354 Manual Swap
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
I know the cases bolt up the same, but what will need to be done in order to make the the dash light indicators for 4 wheel drive work again.
Wicked_Sludge
42
Westport, WA
3-point-GO
the manual case has a 2 wiring harness that goes to it. the wiring has to be spliced into the trucks harness near the drivers side fender. the wire colors escape me at the moment...hopefully someone else will chime in.
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
No splicing required.
there is a weather pack connector near the main firewall connector that
the two-wire harness from the T-case indicator switch plugs into.
the wire colors are pale blue and pale blue with a black stripe.
AD
Wicked_Sludge
42
Westport, WA
3-point-GO
is it part of a bigger harness? ive never been able to locate those two wires on mine :dntknw:
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
