- Dec 9, 2011
- Reaction score
- 2
- Location
- GR Michigan
- Make / Model
- Ford
- Engine Size
- 95' 4.0 OHV
Ok so I swapped in a complete 92 harness out of a ranger in my b2 durning my 4.0 swap
I wAs originally going to use the old 86-88 style switches but after many confusing conficts with a test light and wiring diagrams I opted to suck it up and buy the later multi switch and headlight switch
Once I wired those in I now have another problem
My hi beam indicator is on whenever I pull the headlight switch to headlight mode as soon as I switch to high beams it just gets brighter
Now the most important annoying pArt
With low beams on I'm getting a very dim drivers side lamp, like almost no current. When I switch to high beams it appears they are working fine but you can see that the passenger high beam is brighter then the drivers
I've tried different bulbs, removing and reinstalling the drivers side ground
I'm at a loss, wiring is not my forte at all
And I have other wiring issues to address so I can completely install my dash and trim ect, which is wipers and heater control. But headlights are more important especially with it getting dark at 6pm
Thanks any help is greatly appreciated
Sent from my iPhone using Tapatalk - now Free
