explorer 5.0 ranger swap
HellsRanger
i've been told that this is the easiest v8 swap anyone can do for a ranger. that it has the motor mounts already and everything should fit just right. does anyone have any other easy fuel injected v8 swaps for ranger and do you all know what i need to do the explorer swap into mine??? i got a 99 3.0 ranger extended cab... hopefully doing this by february
mike732
Camden, TN
302
If it has coil springs, the motor mounts will not work but the build is simple..
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
HellsRanger
damn, i think imma just drop it some more and stay more for looks lol... thanks, that was alot of help
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
It looks way more complicated and involved than it really is...If you can pull a motor and re-install it, you can do this swap...Wiring is plug and play, just like removing your engine and re-installing another identical 3.0L...motor mounts, same, unbolt and bolt new ones. I could do this swap in a weekend if you have a donor ( and that's pulling the motor from the donor the same weekend) I was like you and put too much thought into it, did 2 years of researching....I did my swap in about a week's time, but I was doing what very few have done, put an explorer motor into a TTB ranger. The only mods I needed to do were for my oil pan (TTB crossmember is different than 98+) and an oil filter relocation kit (TTB has a gearbox, 98+ has rack and pinion). Check my build thread out, the complete swap is done in the first post, and is also in this month's TRS online mag. You should find all the info you need :icon_thumby:
SVT
hathewaya
2000 2wd ranger
If I have a 2000 2wd ranger, will a 2000 5.0 AWD explorer mount right up to mine? Like can I remove the AWD transfer case and mount up my original driveshaft?
win
12
5.0
No -- the back of transmission is completely different between the RWD and AWD versions. Can be converted as part of a full tear down of the transmission.
If your Ranger has the torsion bar front suspension the Expo engine will bolt in, else with coil springs, you'll need custom mounting plates.
There is no combination of Ranger and Explorer that does not involve some custom wiring.
Staff online
Shran
April Truck of The Month
