homemade lift blocks possible?
1986b2
ford
is it possible to make leaf spring 1 1/2 or 2" lift blocks at home? i have metal saws welding machines grinders etc. .if so what materials do i need?
Capt Jay
Solid Axle Swap
25
Minnesota
'93 body.
Ford(ish)
302
Don't. They are cheap to buy. Or get a set of stock ones off a scrap yard ranger.
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
autozone, they are only like $20...
Andres629
Solid Axle Swap
11
Saskatchewan!
2.9 screamer
Ranger ones. I assume you're trying to fix the sag? I used a stock Ranger block and it worked perfect 'til I changed everything.
alwaysFlOoReD
Forum Staff Member
5,092
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
What's happened to the backyard, red-neck, do-it-yourself attitude??... I'd build it myself using 1/4" plate. Unless I had some kicking around.
Richard
Boggin
48
get the stock 2" blocks from a 4x4 ranger
4.0B2
151
Walls, MS
4.0 v6
Richard
i build most of my own crap... but when its as simply as $20 and i work 40 hours a week and have 18 hours in college classes... running my autozone is easier than cutting/welding/grinding...
now things like a bumper... $160 in materials compared to buying it at $550... hell yeah i'm gonna make it. i find time.
alwaysFlOoReD
Forum Staff Member
5,092
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Andres629
Solid Axle Swap
11
Saskatchewan!
2.9 screamer
See, I'm glad you see where I'm coming from Richard, rather than take offense! :icon_cheers:
For myself, I jerry-rig a lot of stuff together and make it work. But when it comes to the safety and stability of my running gear, I don't want something falling off doing 100 down the highway. Just my $.02 :icon_thumby:
alwaysFlOoReD
Forum Staff Member
5,092
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Yes, there are some who should never attempt to modify their trucks [other than cosmetic...and maybe not even then];
http://www.pirate4x4.com/forum/showthread.php?t=849050
I've definitely changed my opinion on vehicle inspections since I've read this thread, it's too bad that most have children before getting snuffed.
Richard
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
do not use the autozone type aluminum blocks on a 4x4.
get oem or extruded skyjacker types.
the autozone ones are worse then home made steel units on a wheeler. actually homemade steel units are better then oem ones as you can tailor them perfectly.
i busted skyjacker units before and only use the autozone type as temporary when needed. for a street driven vehicle that does not launch hard the autozone blocks are fine....anything that gets its ass kicked and your headed for disappointed.
4.0B2
151
Walls, MS
4.0 v6
i've wheeled and towed on autozone 2" blocks... and never broke them. and gave them away to a guy that's using them still.
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
1 in or 2 in? 1in stouter...2 in fail.
give them to me:icon_thumby:....i will make sure they wont fail on the road.
Staff online
Shran
April Truck of The Month
