Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Suspension & Armor > 4X4 Suspensions
Notices
4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks
Post New Thread Reply
Thread Tools Display Modes
Old 08-21-2012, 10:01 PM   #1
whitetrash96
Junior Member
whitetrash96's Avatar
whitetrash96 is on a distinguished road
Default Cracked Duff radius arm
Recently while servicing my front diff I noticed another crack in my rod ended Duff radius arms. Last year I had a crack welded up on my ears and now it seems I have another crack in a new location. My question is what are people doing to beef up their Duff radius arms?
Unfortunatley photobucket isn't allowing me to upload any new pics
__________________
'92 Explorer Sport, 5-speed, swapped in manual t-case, 4.88s and Ecteds, on-board shower, Co2, Duff 5.5" lift with stock SOA in the rear, coming into its own.
whitetrash96 is offline   Reply With Quote
Old 08-22-2012, 09:46 PM   #2
whitetrash96
Junior Member
Default
Here's where I had the ears welded up last year.
Here is the new crack I found. Not catastrophic but definatley worth looking after.
I've got to get my welder buddy to have a look at the new crack but was wondering if people have braced their arms.
__________________
Old 08-22-2012, 09:54 PM   #3
pillen140
pillen140's Avatar
Year: 1995
Make: ford
Model: ranger
Engine: 3.0
Class: 4x4 off-road
Used For: dd, weekend off roader. and annoying my girlfriend
pillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud ofpillen140 has much to be proud of
Default
i think there is something in the tech library about the duff arms cracking and a fix for it.... might be worth a look for you.
__________________
MAJORITY, THE NEW MINORITY
"Harry..... I TOOK CARE OF IT!!!"
1995 RANGER EXT CAB 4X4, 6" SUSPENSION, 3" BODY, 35X12.50R15
pillen140 is offline   Reply With Quote
Old 08-23-2012, 07:32 AM   #4
88_Eddie
Motorboater (.Y.)
Chopper Challenge Champion
88_Eddie's Avatar
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
i'd just add some 3/16" plate to them for extra bracing
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Old 08-23-2012, 09:33 PM   #5
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Year: 1988
Make: FORD
Model: RANGERISH SORT OF THING
Engine: BIGGER
Class: 4X4
Used For: EVERTHING
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
on the old style i was always twisting and craking/bending them along with wasting d35 beams.
but i was way off the expected path as well as far as power weight and tire size.
for what they are i cant complain. as you beat the fawk out of them you constantly monitor and maintain your whole suspension or build bigger etc....
i just consider it general maintenance.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Old 08-23-2012, 11:28 PM   #6
whitetrash96
Junior Member
Default
Quote:
I had a look but didn't find anything specific to repairing duff arms, thanks though.
I spoke with my welder this morning and picked up some 1/4" flat bar to brace the arms, hopefully have the cracks repaired and new plate installed this weekend. I'll post pics when they're done.
__________________
Old 08-25-2012, 06:30 PM   #7
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
I've seen reports (with pics) of that exact failure a couple times already (failures where the box section tapers down toward the tube section).
Agreed, I would grind out & weld up the crack, followed with a couple pieces of 3/16" plate bent to fit against the arm over where the crack is (a gusset along the top wouldn't hurt either).
How old is that Duff kit?
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 08-25-2012, 07:06 PM   #8
BRONCONUT
Junior Member
BRONCONUT's Avatar
Year: '95~'00
Make: Ford
Model: Bronco~Ranger
Engine: 5.8~4.0
Class: 4x4 Extreme
BRONCONUT will become famous soon enough
Default
I would throw some plate on there instead of just welding it. Another thing that to stop a crack you need to drill a hole in the end of the crack to keep it from running after a weld/fix.
BRONCONUT is offline   Reply With Quote
Old 08-26-2012, 01:09 PM   #9
whitetrash96
Junior Member
Default
Quote:
I've been running it since January of 2006 its seen a lot of use wheeling and daily driving since that time.
__________________
Old 08-28-2012, 09:45 PM   #10
whitetrash96
Junior Member
Default
Got the gussets welded on, while grinding out the ear cracks we found them to be much worse than anticipated and were like spider webs with cracks running everywhere. We cut out the rotten metal and built the area back up with weld, then ground everything smooth and formed radiused corners rather then the orginal 90 degree ones so as to not create any stress risers.
__________________
Old 08-29-2012, 05:57 PM   #11
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Engine: 2.9L, 4.0L
Default
Very nice work!
I'd probably even go a step further and double-plate the ears with another piece of 3/16" plate so they're 3/8" thick, just to make sure it doesn't crack again (at least on the driverside which supports the diff housing).
__________________
'90 Bronco II XLT
'94 Ranger XLT
Old 08-29-2012, 07:00 PM   #12
ThatGuy
ThatGuy's Avatar
Year: 91
Make: Ford
Model: Explorer
Engine: 4.0L
Class: Mall Rated
Used For: bending shock mounts and picking up mountain whores
ThatGuy will become famous soon enoughThatGuy will become famous soon enough
Default
Ahhh, if only I had my way......
__________________
BAMF
ThatGuy is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
