JackLima
- Jul 17, 2014
- Reaction score
- 0
- Location
- Central AR
- Make / Model
- Ford
- Engine Size
- 5.0
- Automatic
I'm new to this bodystyle Ranger, bought one a few months ago for $675 and pulled the engine, replaced all the gaskets and resurfaced some stuff, and stuffed it all back in. I've been driving it for a little over 3 months now and the coolant temp gauge has never gone much above cold, but it rests pretty low it seems when it's cold. Is there a special way I have to bleed it to get it to read right or something? Could a fouled sensor be causing this? The coolant(or what was left of it at least) in the engine when I got it looked like mud, felt like mud, smelled like exhaust, and took a lot of work to remove. It was driven around like this for a little while, but only short distances. The heads weren't crazy warped once I got them off, just a tiny bit out of spec and the head gasket only failed in one place.
TL;DR: My coolant temp gauge doesn't read much above cold(just above the 2nd line from the bottom), what could be causing that?
