Justjoshinya
- Oct 25, 2016
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
I have a 2001 ranger 4.0 sohc edge with an automatic transmission, it has 195,000 miles on it and has been a good truck ive changed a few things on it, the thermostat housing several times, i rebuilt the transmission about 20k miles ago, replaced plugs, wires, and the computer, has a new rearend/axle about 50k miles.
recently it started making a loud rattle or metal on metal noise at rpm's between 2k-3.5k out of these ranges its not noticeable except on startup. i took it to the mechanic he called an hour later and said it was the cats, i said bs but picked it up anyway took it to the muffler shop he said its not the cats. he said sounds like timing chain or transmission. i took it to an actual shop and he said "i dont think its timing chain/guides" he replaced the belt tensioner bearing, and fixed a vacuum leak and replaced the EGR, he also added a "conditioner" to my oil and said he thought my timing guide tensioners are dirty and maybe the conditioner would help. i took it from him, i usually do all my own maintenance but moved into an apartment so dont have space to pull the engine apart too much.
i personally believe its the timing chain tensioner is no good or a failed guide and the chain is expanding at those rpm's causing the noise. the truck runs great beside the noise though i have tried to not drive it too much. i bought the truck at 42k miles and believe the timing components are the original but wont know unless i pull it myself. so now i debate on what to do with my truck pull the engine and fix the timing components or pull the engine and rebuild it and replace components. or drive it till the chain breaks and then dump it, i dont think i could get much for it now with the ominous noise its making.
what would you do?? the money and time without a car are a big influence to me not fixing it.
