think this can be done and how could i pull it off?
mn_smokeater
Firefighter
58
Bemidji, MN
Engine Type
V8
5.4L V8
2WD / 4WD
the question i pose is this:
a 2005 ranger's 3.0 and auto tranny from a 2wd into my B2?
doable?
superds
80
ND
Ford Bronco II
Engine Type
V8
5.0
2WD / 4WD
2" body. 1.5" coil spring spacers/rear block
How much of the original Ranger the 3.0 came from do you have? It's doable, the more you have from the donor the easier it will be. (I'm so helpful, aren't I? :D)
mn_smokeater
Firefighter
58
Bemidji, MN
Engine Type
V8
5.4L V8
2WD / 4WD
comes with engine minus accessorys and the wireing harness and transmission.
pretty much the stuff removed to put a 5.0 in its place
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
You'll have to disassemble the entire transmission and swap the output shaft in order to get a transfer case to bolt up to it.
mn_smokeater
Firefighter
58
Bemidji, MN
Engine Type
V8
5.4L V8
2WD / 4WD
Right. So I would need the proper output and have to match the t case bolts. So im rhunking it may be better to find a 3.0 4x4 manual trans correct?
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Your BII is a manual ain't it?
I'd keep it a manual. Those newer 3.0's put out almost as much power as a 4.0 OHV, should be a decently quick truck. :icon_thumby: Should be an interesting swap, no body does 3.0 swaps.
mn_smokeater
Firefighter
58
Bemidji, MN
Engine Type
V8
5.4L V8
2WD / 4WD
i like that idea and should make it a easier thing i think. might need to make new mounts for the engine and tranny im sure though.
i think i would be the only one:headbang:
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Definitely would be interesting. Anything is possible with enough time and money.....
I've been thinking of a 98+ IFS swap into a B2.......
Just to be different.
mn_smokeater
Firefighter
58
Bemidji, MN
Engine Type
V8
5.4L V8
2WD / 4WD
time i have, money eh il have some some day if my work kicks in.
hoosier1104
I'm Awesome!
MTOTM Winner
TRS Banner 2012-2015
104
Camby, IN
302 based goodness
Work hard and play harder
Who's motor are you try to use? Oh wait, I know the answer to that question already.
<-----------------This guys!
mn_smokeater
Firefighter
58
Bemidji, MN
Engine Type
V8
5.4L V8
2WD / 4WD
needs a tag saying "hoosier powered" on it eh?:headbang:
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Yup. The motor has 80k miles on it. It has iridium plugs, AMSOIL (that needs to be changed), KN air filter. It was babied since I have had it since July of 09.
mn_smokeater
Firefighter
58
Bemidji, MN
Engine Type
V8
5.4L V8
2WD / 4WD
is it a flex fuel?
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,753
SW Iowa
Engine Type
V8
5.0
It has been done in a BII before.
Been a couple forum versions ago but I remember somebody was all bummed that somebody stole it and wrecked it. He was impressed with the speeds it reached in the chase though.
I think it was back before I was a regular though, I didn't really know anyone yet.
mn_smokeater
Firefighter
58
Bemidji, MN
Engine Type
V8
5.4L V8
2WD / 4WD
looked a bit didnt find anything current really showing the nuts an bolts of it
Staff online
Shran
April Truck of The Month
