Does a 89-90 Fisher plow fit a 87 Bronco II ?
Connecticut unfortunately.
351W , 2.9L , 4.0L
I have found a Fisher plow from a 89 but not too sure if the frames are different on the 87.
I know the bumper is different.
So I am asking if anyone knows if a 89 plow will fit a 87 ?
Thanks,
1RangerNut
Central,IL
2.9L
The plow off my old 88 B2 didn't fit over the frame rails of my 89 B2 "frame is wider".
Could probably make spacers and mount it to your 87.
Diesel_brad
Gilbert PA
Thanks,
YES. the front frame rails are the same from 83-92. They may even be the same all the way till 98(the last year of TTB)
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
My experience; 1986 ranger has a round front frame section that the bumper bolts directly to. 1991 frame is straight cut with convoluted sides and the bumper bolts to a bracket that bolts to the frame. So not exactly the same.
Sent from my XT1032 using Tapatalk
cannonfodder
if you got a torch and a welder and know how to use it it fits
Junkyardexpress
ASE Certified Tech
Ellsworth,Maine
2.9L
P235/R15
I bolted a fisher plow from a 88 or older ranger onto my 91, I had to delete the bumper on mine for clearance. As far as the frame issue, the front of my frame got crunched sometime early in life so I don't know how frame much modification will be required if any.
No members online now.
