| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8 |
Thread Tools | Display Modes |
#13 | |
Junior Member
Quote:
Looks like im gonna hopefully start tearing apart my d44 tomoro! Pretty stoked, thanks again. Will probably have more questions upon the install, So keep an eye out, your help would be awesome!
__________________
93 ranger "power ranger" 4in RC suspension 33's gy wrangler sa's aem intake custom exhaust |
Tweet
#14 | |
2010 OTOTY Winner
Year: 1991
Make: ford
Model: ranger
Engine: 460
Class: 4x4
Used For: stupid stuff
Rep Power: 22 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Quote:
i'll have to take another look at it to see what else i did,that was a few years(and projects)ago....but i still have it.
__________________
just the facts,ma,am-joe friday |
Tweet
#15 | |
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: daily driver, trail ready
Rep Power: 8 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Quote:
Sent from the road while ignoring traffic |
Tweet
#16 | |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Quote:
FWIW, the bigger brakes would be the only real reason I see for this swap myself, I've had 0 issues out of the stock D35 setup using Timken brand bearings and the Warn Jeep hubs. That is not to say the D44's bearing setup isn't better (it most certainly is), but I'd maybe try switching to Timken brand bearings & races (SET-37) if you're having issues with it, which seems to solve the problem for a lot of people.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
#17 |
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
I was using the Timken bearings but was blowing them up just as fast as the cheap ones. My problem is the wheel/tire combo I have are around 100 lbs each (37" tires on trailworthyfab hummer wheels). This puts enough stress on the bearings that during the winter when I couldn't ride I was going through bearings once a month or two. Good to know that I can't get the adapters to fit before I started to do this. Would've been a huge waste of money for nothing.
Tweet
#18 |
Mall-Rated
Year: 1990,1994
Make: Ford
Engine: 2.9L, 4.0L
How are you tightening your D35's bearings? I'm thinking regardless of your tires the Timken bearings should last at least some amount longer than some cheapo ones...
I went out and looked at the D44 hubs on my Ranger, I'm now thinking there could be some possibility you could make it go together, however I'm still not sure how comfortable I'd be with it. You'd probably end up with around 5/16" thereabouts between the studs and the I.D. of the adapter on the 4.5" side (which I'd certainly want the adapters be made from steel, I think that's too thin for aluminum ones). The next thing would be how much meat would be left on your wheel centers if you widen them. It'll be tight getting a nut & socket in between there for sure.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s Last edited by 4x4junkie; 06-24-2012 at 08:27 PM. |
Tweet
#19 |
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
The centers have tons o room. However at the dfw meet today hazmat mentioned that the d44 hubs are to big like you mentioned so it's time to stop procrastinating and get the d60 under the truck.
I was tightening the bearings a bit tight. Last time I did the bearings I only seated the bearings then tightened the outer spindle nut as much as possible. So far its lasted longer but I use the bike as much as possible. 45 mpg on a motorcycle beats out 15 mpg in the truck IMO. Sent from the road while ignoring traffic |
Tweet
#20 |
Mall-Rated
Year: 1990,1994
Make: Ford
Engine: 2.9L, 4.0L
The inner nut only needs 15 inch-pounds, no more (some say 16 inch-lbs, close enough), then the outer nut goes on to 225-250ft-lbs (making sure the inner nut & washer doesn't try to turn with it).
If you got a 60 on hand though, then what the heck are you waiting for?
__________________
Tweet
#21 |
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Money, of all the threads started saying they where doing a cheap swap easily turned into a $1500+ job. I have college, no place to work on it, and non existent funds to use. And I won't be that guy that uses a credit card to finance a SAS.
Tweet
#22 |
Mall-Rated
Year: 1990,1994
Make: Ford
Engine: 2.9L, 4.0L
No doubt, I hear you there...
Well, good luck on your D35 then... I think you should get at least a couple years out of it with your setup if you get the preload right on it. I put MT/R-Ks on my rig early last year and with the steel rims they are probably within 15lbs of what yours are (MT/R-Ks are heavy-ass tires). And that's on bearings that have already endured 12 years & 70K miles with my prior BFGs and the mileage under my Ranger before I did the D44 on it. Alright, giving the thread back to the OP.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
