Misfire 2005 Mazda B3000
canucker
No Fords.....ye
Hi all
I have a 05 Mazda B3000 (automatic, rwd) that seems to get misfires every so often. it will idle normally and then start misfiring and the truck shakes, but then give it gas it sorts its self out.
Or ill be driving and then it looses its power and i floor it then it takes a bit but the rpms shoot up and she starts moving again. The check engine light will come on (flashing) when it does this and then later shows solid check engine light. ive scanned it (seriously the best tool to have for working on your own vehicles) and its showing misfires in some cylinders.
thus far ive replaced the ignition/distributor (old one was cracked). fuel filter. im not sure whats next
Please help its cold and i just want my truck working right:sad:
Sean
locovaca
4
DeWitt, IA
3.0
If you replaced a Distributor then you don't have an 05... only the 94 B3000 had a distributor.
When is the last time you changed spark plugs?
canucker
No Fords.....ye
im not sure what the parts called but its the igntion coil with all the plug wires coming off.
i havent changed the plugs yet may do that today then.
thanks for your help
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
646
Central Indiana
3.0
I'd look at plugs, wires, cleaning the MAF, and if none of that helps, start testing the fuel injectors
canucker
No Fords.....ye
well good news. got new plugs NGK v-power. put them in and it seems to be running much better. the power is all back. seems to still shake a little when ideling.
also fixed my hood latch today!
thanks guys:icon_thumby:
Staff online
Members online
Shran
April Truck of The Month
