M5OD-r2 fitment
Nate.Mountain
3
Idaho Falls, ID
2.9
Long story short I am planning and beginning to collect the necessary parts for a 302 swap. Currently I have a Md05-r1 behind my 2.9, and I would like to keep the 5 speed. I would love a zf trans but fitment without a body lift looks near impossible, which means I'm going to go with the md05-r2. Based on the reading I have done, in order for the shifter to be in the right place I need a 99 or later Mdo5-r2 out of a 6 cylinder correct? I found a screaming deal on one out of a 99 6 cyl f150. I wanted to verify that this trans will work and has the shifter in the right location.
Also, will I need to adapt my driveshaft at all using this trans?
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Its 1997 and up from a 4.2l V6, found in F-series and some E-series trucks, and of course 2WD or 4WD according to your plans
Same bolt pattern as small block windsor, i.e. 302, but you will need to make the bolt holes in the bellhousing slightly larger, 4.2l used metric, 302 is SAE
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,814
SW Iowa
Engine Type
V8
5.0
Trans is about an inch shorter IIRC than what you have now, how your engine sits in your truck if you are 4wd your t-case will factor into it too.
Pop it in and see where the chips fall.
Nate.Mountain
3
Idaho Falls, ID
2.9
Thanks for the replies, great information. My truck is 2wd so I won't have to worry about finding a tcase that will fit. Did not know about the holes being too small, good to know so I can drill them out in advance. What size should the be drilled? Planning on using the motor mounts from the conversion kit from jegs. I guess I'll have to wait a see if the driveshaft is long enough or not.
I am doing the swap mid October, and I'll have a full week to do it. From now to then I'm collecting parts and trying to work out all the kinks i can think of so it will go smooth as possible.
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
Engine Type
V8
5.0L GT40
2WD / 4WD
2WD
I have 5.0/MD05-R2 in a 2wd Supercab 2000 that had a 4.0/MD05-R1 in it stock.
I used a 99-03 f150 300 inline trans
My existing 4.0 driveshaft lined back up perfectly.
The shifter hole lined up perfectly.
The bellhousing holes need to be drilled to 1/2".
The two bolts on the rubber trans mount where about 1/2"-3/4" past the mount holes on the trans crossmember, I just slotted the holes on the frame and slid the crossmember back and rebolted. (you can also slot the two middle holes on the crossmember instead of moving the whole crossmember back, or a combination of both.)
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,814
SW Iowa
Engine Type
V8
5.0
300's died in 1996, if you used a 99-03 trans it was a 4.2 V6. The earlier shifters would fit in Ranger's terrible so that is probably what you did.
4.2's used 12mm bolts for the bellhousing, SBF used 1/2". May take a little different size for the alignment dowels, I haven't checked too far into that.
And when I said the trans is an inch shorter, that is for 4wd's. 2wd's may be different.
V8 Level II
Dec 2008 STOTM Winner, 2008 Truck Of The Year
MTOTM Winner
RBV's on Boost
4
Michigan
Supercharged 5.0L
289/300/302/351 all used 7/16-14 bell housing to block bolts. I drilled my 97 M5ODR2 from 12mm to 29/64". A 15/32" bit would also work if that's what you have available. Going to 1/2" is probably ok but it's larger than necessary.
The alignment dowels are the same size for the 97-up metric R2 and the Windsor block. No worries.
Nate.Mountain
3
Idaho Falls, ID
2.9
Thanks again for the info. There is a ton of variables in these swaps but knowing at minimum that the trans will bolt up, is approximately the same length, and that the shift will be in the right location is great to know. I want to avoid cutting the floorboard if at all possible.
Here is pictures of my truck currently. The 2.9 has 355,000 miles on it. This site has helped me with just about everything I have done to the truck.
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
Engine Type
V8
5.0L GT40
2WD / 4WD
2WD
Sorry for the misinformation yes, I used the 4.2 v6 version.. The inline 300 was the early version MD05-R2 and shifter is closer to the dash and doesn't line up in the ranger shifter hole nicely like the 99-03 later version does.
The stock 302 dowel pins fit the trans fine, I didn't have to change anything there.
Nate.Mountain
3
Idaho Falls, ID
2.9
Another question regarding the trans. Will the master cylinder on my truck work? Is it compatible with the slave cylinder on the trans? If not what should I swap I swap out? (Truck is an 88, trans coming out of a 99 f150)
RonD
Official TRS AI
8,370
canada
No, around 1992 the master/slave Quick connect fitting changed, so get a new master to match the new slave.
Later model master will fit into older model Rangers, only the connector was changed as far as I know
Staff online
Today's birthdays
Shran
April Truck of The Month
