$350 for battery cables!?
sugarshane
I have a 98 ford ranger with a corroded positive battery cable. Ford wants $350 bucks for one because it has an inline fuse I guess. Does anyone know where to get one for a decent price thats not used?
COPPERHEAD85
41
west tennessee
ford
302
you could make your own for alot less than that.
Donnie strickland
MAKG
19
California central coast
4.0L
You can still make your own for a lot less than that. Make sure to make it weatherproof.
When I made mine, I had to use a propane torch for soldering, and I weatherproofed it with heat-shrink. Still holding fine after 3 years...
Keep the stock electrics or it may not work right. Some RBVs have a rather odd setup, with two relays, mounted separately. The starter cable is hot all the time.
bottledgt
ford
just go get a universal one at autozone for like 10 bucks
Earl43P
38
Farmington, Pa
Ford F250 4WD
3.0
For real.
It only goes to the UHJB and the starter. I don't see any fusible links.
"String" the lengths and buy the one that's closest (but not short).
For that matter..."electrically" it is "equivalant" to run the Bat+ to starter leg from the UHJB, if you wanted to use two seperate cables. One red from Bat+ to UHJB. Use the same UHJB terminal stud to run the second red cable straight to the starter. Done. Cheap.
Staff online
Shran
April Truck of The Month
