I'm finally doin it
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I'm puttin my 4.0 from my ranger(auto) into a early 90 B2 that I bought recently. I've got a 5 day weekend comin up and I figured what the heck. Plus my gf blew up the 2.9 in the B2. Any suggestions?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
DO it , do it naow.
88_Eddie
Solid Axle Swap
155
Raleigh, NC
2.9L, 4.0L
Any suggestions?
keep your gf as far away as possible from any vehicles you currently own. i'll also recommend a year-round bus pass as a new stocking stuffer
good luck with the engine swap
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
do all the research on the wiring up front... it's a pretty straight forward swap. but i had to go sit down a couple times and get away from the wiring. I have an 88 b2 with a 92 exp 4.0... you will love the gain of power over the 2.9 and i get better gas milage
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
She's driving my tan B2 right now, hence the urgency of getting the other B2 fixed. Tan is holdin up fine, he's next in line for a 4.0. That 2.9 is holdin up pretty good tho.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Update: Got 2.9 out, got 4.0 out. Will I need the power block from my 94 or can I use the one in my 90? My 94 is a 2wd ranger, and my 90 B2 is a early 90 w the D28 and 1350 t case. I'm just wondering how this will effect my 4wd in my B2. I have a manual t case and manual; hubs to put on it if I need to. Just wondering ? Tech library wasn't to specific and I haven't picked up on it anywahere else. I guess this is why everyone suggests using a explorer.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
:annoyed:AARGH!!! Plug and play my a$$.
This is a PITA. Will I be able to keep my elec T case since my donor is a 2 wd ranger?
Where is the relay for the tcase on my B2?
What about my power windows? :dunno:
Members online
Shran
April Truck of The Month
