- Mar 9, 2012
- Reaction score
- 4
- Location
- Ohio
- Make / Model
- Ford
- Engine Size
- 3.0
- Automatic
A little back story... wheeling last weekend, swallowed water, a lot of water. Didn't hyrdro lock the motor, and it got out of the hole under it's own power, didn't stall out or anything. On dry land it ran even worse and I pretty much had it pushed home. Left her for the night to dry out...
Barely ran in the morning, everything was still pretty wet. Played with it, took the cat off (maybe clogged from water, no idea), checked for spark. Wasn't getting spark from the coil. Cleaned the MAF, threw in a new coil, some spark, checked the ICM, good. But now when it ran I noticed quite a leak on the block where it used to be a pinhole of coolant, is now a decent drip. Time for head gaskets... Left the original problem at that.
Did a head gasket job by the book, dotted my I's and crossed the T's, ducks all in a row. Checked compression and it's between 165 and 175psi. Without even running the motor (I noticed the permatex beads on the new gaskets, so they need to heat up and what not to seal completely.) Put everything back together right, and even painted my valve covers blue to match my suspension.
Cranked it over... and nothing. Starter turns, motor wants to catch, at least one cylinder was firing (smoke out the Y-pipe, cat/exhaust disconnected). Can smell gas so I know it's getting fuel, and of course it's getting air.
Now the real mind bender. During the tear-down, on the wiring harness that has the injector connections, running back down to the firewall off the motor with a little bracket on it, there's 4 pigtails on the end. 2 for the O2 sensors, one that meets up with the speed sensor/reverse switch, and another one. It's a 2 pin connector, that is perfectly clean, like factory clean. I can solemnly swear up and down that I didn't disconnect it. The wires going to it are Purple/Yellow and Orange/Yellow. It's a more-so circular connector.
Running through wiring diagrams, wearing out the multi-meter, and searching the web, all I can find is possibly a octane adjust shorting bar, or a torque converter/gear sensor. Should that even be there? Also this truck is a 5 speed, and doesn't have an EGR system.
Maybe I can get some pictures posted up.
