Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4WD Systems
Notices
4WD Systems Transfer Cases & Locking Hubs. Forum sponsored by The Shiftster
Post New Thread Reply
Thread Tools Display Modes
Old 07-11-2012, 05:05 PM   #13
Kevery
Premium Member
Kevery's Avatar
Year: 1999/1978
Make: Ford
Model: Ranger F250
Engine: 4.0 V6
Class: 4x4
Used For: Everyday driver/wheeler
Kevery is on a distinguished road
Default
Is there such thing as a 1354 manual case? Can I use two 1350 manual cases? I have no problem with using two manual cases since I'm probably going to have to buy two anyways.
If I can find a 1350 in 83-89, what about a manual 1354 (if there is such a thing)?
__________________
My wife asked me to take her somewhere expensive... so I dropped her off at the gas station
The more people I meet the more I like my dog
Biuld Thread http://www.therangerstation.com/foru...74#post1276474
Kevery is offline   Reply With Quote
Old 07-11-2012, 05:57 PM   #14
crawlin91
I ain't got time to bleed
crawlin91's Avatar
Year: 91,92
Make: Ford
Model: Ranger
Engine: 2.9, 4.0
Class: 4x4
Used For: running stuff over
crawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud of
Default
I would grab a 1350 case and cut it up to use for the front case, as the area you will have to block off is much smaller on the 1350 than the 1354 due to the case design. Also, I dont know if Duffy makes the adapter "filler-plates" that will fit the 1354 case.
1354 manual and electric cases can be found in some 89+ Ranger, BroncoII, Explorer
The 6 gear planetary 1354 tcases can be found in 92-97 Rangers and 92-? Explorers.
the 6 gear is a sligthly different design of shift fork and internal gear set, IMO better than the 4 gear planetary (of the older 1354 and 1350 cases)but either will work just fine.
You can run an electric rear case or two manual cases but the front case must be manual. There are many different shifter configurations you can do depending on which way you go.
__________________
RMR '92
crawlin91 is offline   Reply With Quote
Old 07-14-2012, 05:28 PM   #15
Kevery
Premium Member
Kevery's Avatar
Year: 1999/1978
Make: Ford
Model: Ranger F250
Engine: 4.0 V6
Class: 4x4
Default
this might be a dumb question but can I use two 1350 cases instead of one of each?
__________________
Old 07-14-2012, 05:59 PM   #16
crawlin91
crawlin91's Avatar
Year: 91,92
Make: Ford
Model: Ranger
Engine: 2.9, 4.0
Class: 4x4
Default
yes, two 1350 cases will work
__________________
RMR '92
Old 07-14-2012, 06:15 PM   #17
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Word of warning, I doubt it will clear your fuel tank with the tank in its stock location.
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 07-22-2012, 04:28 PM   #18
Kevery
Premium Member
Kevery's Avatar
Year: 1999/1978
Make: Ford
Model: Ranger F250
Engine: 4.0 V6
Class: 4x4
Default
I have a custom fuel cell planned out. I'll just add it to the list I guess.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
