| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: Puddle jumpin,gettin stuck
Rep Power: 9 ![]() iTrader: (0)
So I have been looking for a 4bt religiously lately and haven't gotten anywhere. And in order for me to run it I will be doing a sas on my truck. Now my question is what should I do first? Find a motor or or swap axles? Opinions please.
__________________
My Build Thread: Clicky! Mods:4" RC lift,33's,rednecked fender flares,toolbox. Plans:SAS and 38's |
Tweet
#2 | ||
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (13)
I would do the axle first.
The way I look at mods is this: If one mod needs another for it to work properly, do everything else that the desired mod needs first, then do what you want.
__________________
Project: Hillbilly Deluxe Project: Amazing Grace Project: 12-Volt Sandwich Quote:
Quote:
HELP REPEAL OBAMACARE Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind. |
Tweet
#3 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Trail Slut
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (1)
Along with a SAS the truck is usually being lifted. It is easier to work on the truck when it is lower to the ground. I say motor first. Also the 4BT I believe is heavier than the stock engine and that could come into play with the front spring rates.
__________________
HE WHO DIES WITH THE MOST TOYS WINS |
Tweet
#4 |
Year: 1996
Make: Ford
Model: Ranger XLT Standard Cab
Engine: 2.3l 4 Banger
Class: 2WD
Used For: DD and light duty
Rep Power: 9 ![]() ![]() ![]() iTrader: (0)
my thoughts exactly
__________________
96 Ranger 2.3l 2WD Manual 5 Speed *Throttle Cable Mod *Permanently Fixed Cigarette Lighter *Snorkel Mod *4" Rough Country Lift
Tweet
#5 |
Boost Junkie
Year: 94,94,95,01
Make: All 10 are Ford
Model: Ex, Cobra, Ex, Ranger
Engine: 4.0,5.0,4BT,4.0
Class: none
Used For: Going places.
Rep Power: 44 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (3)
I would do them both at the same time.
If you do the engine first, you'll have to chop more out of the oilpan and less out of the crossmember. If you do the axle first, you'll have to have your front driveshaft modified twice and you may have to change front springs again. If you do them at the same time... you can cut the engine crossmember out and build your own to fit with the axle and engine. You only have to have driveshafts made once. You only have to buy springs once.
__________________
'95 Explorer -- EEC-IV SOHC swap. Now getting a "moderately built" 4BT Cummins, ZF, 4406, US Gear OD unit, 13" Cobra brakes, '99 Cobra wheels,.... 4BT swap thread Ranger bed trailer build Scars are just tattoos... with better stories! |
Tweet
#6 | |
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Quote:
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
