bajascott
- Jun 8, 2011
- Reaction score
- 2
- Automatic
new fuel pump,new pressure regulator.new coolant temp sensor,timing is dead on,plugs good,wires new.yadayada
pops through the intake and has no power above 3000 rpm.
took to a mechanic and he said the cam was flat.
I honestly don't buy it....but what do I know.
I bought truck a while back from a kid that said it had a vacuum leak and that was why it ran like crap. I drove it, it had all the symtems of a bad fuel system, so I replace the above parts, it ran a little better, but it still has these problems. I have check vacuum leaks all over the intake and there are none.
I have not checked vac pressure yet, I really don't think that's a problem.
everything that is vacuum operated works like it should.
any suggestions?
it idles great,starts right up
any suggestions?
