Filler tube leak
86ranger4x4owner
2.9l
I have an 1988 ford ranger with the automatic A4LD and transmission fluid is coming out where the dipstick tube sits into the transmission. I took it off and see no o-ring. My question is should it have a o-ring or is this type supposed to be pressed in? If it's pressed in what could I use to seal it? Thanks.
There should be a seal of some sort. Not so much an o-ring as a rubber sleeve, but same idea.
