- Oct 25, 2015
- Reaction score
- 7
- Location
- Bismarck ND
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L OHV
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 4"
- Tire Size
- 32's
- My credo
- Break. Upgrade. Repeat.
I am in the process of regearing my 1992 explorer front differential to 4.10. I ordered the new ring and pinion from RockAuto. My question is this:
The gears that showed up are the opposite cut from the factory. They are listed as for the 1992 Explorer Dana 35 front axle, but I think they are meant to be for the Jeep Dana 35 rear axle. Obviously the ring gear that I was sent will match the pinion that I as sent, so the vehicle should still move with the set I was sent. Is the ring/pinion direction set up to be sturdier in forward than reverse? Am I able to use the set I was sent?
Part: 2020487
Here is a link to the product:
http://www.rockauto.com/catalog/moreinfo.php?pk=4956537&cc=1119619&jnid=545&jpid=26
Any input will be greatly appreciated.
Thanks.
- Joe
Part: 2020487
Thanks.
- Joe
