Bronco II custom quarter window flip up
jollykreiger
Ford Explorer
I have used plexi several times. In 2 back windows and took the piece out of the 2nd one I did and reused it in the bronco for now.
By bending plexi do you mean permanently or any kind of real bend. Because when I brought it home I had to bend it from the front seat around to the back seat in my vert mustang.
I do understand that Lexan is a different plastic and is way way stronger and a superior material in almost every way.
I used to run Poly Carbonite injection molding to make shelf supports so I understand some of the properties of that but never put Lexan and PC together.... Interesting
In the end I think Im just gonna make a vinyl roll up window with button snaps. It would work better for the hunting and offroading I do.
Spede Demn
Irricana AB
'85
2.8L
Plexiglass will bend a little but it will return to its original shape unless its heated, lexan can be bent in a press just like metal sheeting so you could make it curve to match the body. Although lexan will spring back some so it needs to be overbent at first and allowed to relaxe a few minutes, after that it will retain the bend/curve permanently. Plexi/acrylic is more scratch resistant but lexan/polycarb is stronger, when laminated together in multipul layers lexan becomes bulletproof glass.
I work in metal fab but we often work with lexan also, its quite easy, no special tools required, I just added some air deflectors on my Honda bike last week so I can get a couple extra weeks riding in before snow flys.
jollykreiger
Ford Explorer
Nice, I have a klr and I just bundle up with thermals and a cut balaclava, as long as its not freezing I'll ride
