jjmcooley
- Apr 25, 2016
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
Hi everyone. I did a v8 swap from a 1998 ford Explorer 5.0 into a 2001 Ford ranger edge, I used the PATS and transceiver and ignition switch and engine harness from the Explorer, I have 55 psi at the fuel rail, I also checked the neutral safety switch PK/W and PK wire to make sure the pin was ok, and it was, My problem is the truck will not turn over, meaning it will not try to start, can someone please help me out here, Thank You
