Removing Interior Door Panel 2008 Ranger
Muscleford
Streetsboro Ohio
4.0 SOHC
Anyone know how the interior door panels on a 2008 come off? There is one screw at the bottom at the edge on the striker side. Are there pop out clips or are there buttons you need to slide the panel up to release.
Thanks
George
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
Solid Axle Swap
19
Farmington Il.
4.0
Pull the screw and lift the panel straight up. Once you get it off you'll understang how it stays on.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Not sure how much the panels have changed since '98, but these had screws very well hidden.
One was buried in the carpeted panel near the bottom (maybe the one you mention), there was another screw that required pulling off the black trim surrounding the handle to get to it.
Once the screws are out, then it just lifts up & off as Brett mentioned.
bbking9
2008 Ford Range
1992 BMW 525i
Like Brett said - there are 2 screws - remove screws and then lift up - dont pull the panel out - like older cars - BUT PULL UP !!
08ranger4x4
Texas
the 08 should have the one on the bottem then theres the 2 in the arm part on the door(the cup thing) pop off the plastic around the door open handle and theres one more there
ranger_tomm
SE PA
4.0L
locovaca
4
DeWitt, IA
3.0
Unless they changed things, they're 6x8 in my 93.
09ajmaros
Wisconsin
3.0 Flex
Yep 6x8 i think
KrosbyS
Any suggestions on how to remove the rear door panels in the supercab sport??
09ajmaros
Wisconsin
3.0 Flex
Is that with no rear swing doors, krosby? If so the whole plastic panel might have to come out, but I'm not sure because I never dealt with one of those.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
Solid Axle Swap
19
Farmington Il.
4.0
Pull straight out real hard. They are held in by the metal type spring clips
KrosbyS
Yes it has rear swing doors and the problem i cant pull them straight out cause it conflicts with the seatbelt attachments..The lower clip for rear passenger to clip in i can work around but its the upper belt releasing mech. for the front i cant figure out...there are no screws on the rear panels??? Any suggestions? If im not clear then i may just take a photo of it then post. Regardless thanx for the quick replies '09ajmaros' and 'explorin94'
ranger1014
Bobcaygeon Ont Canada
3.0L
hey dude its really easy just unbolt the seatbelt at the top you well have to remove a small plastic cover to get at the bolt then pull it off the hardest part is putting the plastic clips back on...
Members online
Shran
April Truck of The Month
