Bronco II 5.0 swap ...what electric fan works with depth?
surratt
jesus I only have 2.75 inches to work with which rules out alot of good fans.....Looking like im going to have to deal with 1000-1300 cfm fans. Is that going to be good enough to cool this engine in traffic? Any good fan recommendations at a decent price for that depth. Im using the aluminum advance adaptors radiator by the way
toledo_tommy
Ohio
302
Are you going to be running a pusher or puller fan ? Which side of the radiator will give you more room for a fan ? I just picked this one up for my set up . . . . . I'm going to be using a pusher fan tho because I had to move the engine all the way up to the radiator .. ..
http://www.jegs.com/i/Flex-a-lite/400/119/10002/-1
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
you seemed to answer your question.
engine placement and radiator type and placement are the main key factors.
when you compromise one ideal, you usually have to change up stuff down and upstream.
engine final location at "a", can use fan "b" with radiator type "c" if radiator is in location "d" and so on.
no easy answer. save for all of the fan dimensions available in the world.
i have had guys tell me it is impossible to fit a taurus fan in a 4.0 or 5.0 trucks.
all i can do is laugh about that. it sure as hell rules out 3 foot wide radiators and v8 diesel swaps.:dunno:
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
i would not be afraid to clearance the grill and put a taurus fan up front anyway depending on the application.
toledo_tommy
Ohio
302
Taurus fan wouldn't fit in my Ranger ( as a pusher fan ) with the 4.0 radiator . If the clearance in the bronco is as the rangers then the pusher fan I posted may work for your set up.
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
if the radiator is in the stock location it will fit.
you just have to make it fit.
toledo_tommy
Ohio
302
Do you cut it out of the shroud its molded in ? Or did you have to fab the front to get it in there ?
dangerranger83
5.0 HO under the hood!!!
Solid Axle Swap
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Im running a Taurus fan in mine with a 5.0 and explore rad. I didn't get the engine back as far as I wanted so I had to cut the core support a bit too get the rad to fit.
surratt
puller fan i guess the only way to use a pusher is cut up the grille and cut out the core support which id rather not do but 2.7 inches is not alot to deal with in the front
surratt
yeah i doubt a taurus fan would fit as a pusher or a puller with this radiator/5.0 setup just not enough room. The engine is as far back as i could get it as well. Was that pusher fan enough to cool your motor down during traffic and at idle?
surratt
please post some pics and give me an idea!
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
I ran two 10" fans with a mounting depth of 2.25", flowed 2400 cfm, combined. It was adequate, but heated up on the trails. I was planning to run 4 eight inch fans, but have since changed designs...
SVT
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
your style truck has a good 5 inches more room forward, and i have 7 inches to a standard water pump here and could squeeze a taurii fan in there
on edit, the grill is modified as well and cut down on the inside for clearance.
surratt
SVT
any pics of your setup...this advance adaptors radiator i have doesnt have alot of surface area to work with....17x16 i believe so im pretty limited. I may look into the two 10 inch fan options.
Members online
Today's birthdays
Shran
April Truck of The Month
