2nd gen Explorer 4.0 OHV ok for swap ?
Sorry if this has been discussed. I have to work later tonight and I don't have time to do the research.
Anyway, I found a 2nd Gen Explorer with a 4.0 OHV engine, its got a ceramic/black plastic intake. So, I'm not certain of the exact year of the truck but it is a push rod motor. after a quick Wikipedia search I found the OHV 4.0 remained in production until 2001. That being said, does that mean I can complete the swap as if it were a 1st gen Explorer ? I mean, as far as I know I can either simply swap the computer/engine harness and have it running. On the other hand, would I have issues doing a complete re-wire of the entire truck if I decide to go that route ? I'll be keeping my Mitsubishi 5 speed and electronic 4x4 for the time being, my BII is a '90 2.9L.
Forgive me, but I just want to be certain this engine is EXACTLY the same as the 1st gen before I attempt to buy this Explorer.
Thanks for any advice.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The base engine is exactly the same as the 1st gen Explorer. Depending on the year the electronics, sensors and what not, on it are drastically different.
I also don't' guarantee that the wiring is right. I do guarantee you have wiring issues concerning lights if using an Explorer harness on a Ranger or BII.
So the engine is basically the same ? If I understand you clear, I would be ok using the engine with a early 4.0 Ranger harness then ? Just how drastically different is this sensor variation you speak of ?
The Explorer only has 107K miles. Its been parked for a while. I figure it could make it another 80,90,100K if I'm good to it.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The biggest issue is the cam position sensor. It changed around 1997 from a 3-pin to a 4-pin. The syncro changed at the same time. Basically, look for an engine from before the change and you should be ok with almost everything else.
Today's birthdays
Shran
April Truck of The Month
