body lift or suspension lift
blakeandress1
whats better if im just going for a cool look to my 95 bone stock 2.3l 2wd standard ranger a small body lift so i can out bigger tires on it or an actual lift kit? whats cheaper easier, safer for truck, will cause least damage or affects on truck, and will let me do it without having to add anything extra?..i just want something i can slap on and thats it no other parts or work needed for it to work?
nb11
10
South Georgia
2.3l
Body lift for sure will meet your criteria.
blakeandress1
thanks man!what kind you thnk?and do u have that on your truck?
03ranger30
5
Mount Airy, MD
3.0L V6
I am personally against body lifts, sure they are somewhat cheap if you want some lift, but I think poorly done ones look stupid, just my 2 cents.
I agree, but if you just want cheap height and don't care about a huge gay gap above your bumpers, body lift is the way to go.
blakeandress1
what size do you think i should do?and what tires could safely fit to where they dont rub or cause dramatic drop in gas milage or performance
blakeandress1
how size you think will look good and wont cause me any problems to my trucks body or performance
killj0y
11
Edinburg, TX
2.3l 4 Banger
Fix it till its broke!
With a body lift you don't run much risk of anything really. Just get it done right that's all. Bigger tires means bigger gears if you don't want to lose too much performance.
blakeandress1
ya thats wat i was thinking.. what tires should i use? 225/60/15 or 215/60/14 or what?idk how to calculate any offroad tire sizes and want something tuff but not too big or expensize like i think something alilbit smaller than 31's
killj0y
11
Edinburg, TX
2.3l 4 Banger
I run 31s fine with 3.73 gears...
But then again I didn't need a lift for that too. If you want smaller than 31s don't bother getting any kind of lift lol. Besides it will name the tires look even smaller...
blakeandress1
oh ok so if i do any body lift at all 31's will work ok? and you said ur gears are 3.73..is that stock or did you change them? cuz idk what gears are on my stock 95 2.3l 2wd...i mean if urs is the 2.3l 2wd and all ur stuff works fine without power loss then i got nuthing to loose
6.2
11
Rural Manitoba, Canada
With tha engine id recommend bumping up to 4.10's but that's just me.
With a 3" body lift you should be able to fit 33's unless it's different for older trucks.
6.2
11
Huge gay gap above bumpers? Wtf are you talking about lol. Body lifts come with bumper brackets to relocate them so there is no gap.....
Some of them do. A lot of cheaper ones (IE JC Whitney) do not.
blakeandress1
how do you change gear ratios? and why do u reccommend that?
