My build thread
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
5.5 in susp 2 in body
hey all, finally getting a few things done on my b2 and thought i would keep a log of this project. my b2 is an 86 eb, been sitting for a few years, paid 400 for it and towed it home. when i got it home i put in a new computer relay and it fired right up!
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
subscribed. Love me some B2's
kaytor692
2
ford bronco ll
400 bucks vary well spent if i dont say so my self. nice b2
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
got the front lift on, superlift brackets and bds coils,still need shocks and brake lines....rivets suck!
4.0B2
151
Walls, MS
4.0 v6
custom long arms are easy if you know how to cut/weld.
there's a brake line extension in the tech library about using 2 pieces that are easily found at parts houses near you.
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
going to tackle the rear tomorrow. have some add a leafs and a lift shackle, not sure if ill get enough lift out of them though.
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
i do know how to weld and just bought a small welder, so i might look into this....any ideas or links?
i am going to do the brake lines from the tech library...lol
88_Eddie
Solid Axle Swap
155
Raleigh, NC
2.9L, 4.0L
looks good so far
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
thanks guys....i have a lot of little stuff to do after i get the lift on...broken seat frame,wheel refurbish and tires, door panels, drop pitman arm(anybody have one for sale??) and the list goes on and on...lol
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
ended up putting a lift block and add a leaf in the rear, will put the wheels on tonight and see how it sits....should i hook the rear sway bar back up?? i was going to use the longer end links on the front sway bar....want to be able to drive it without it having a ton of body roll. will a front be enough??
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
found a great deal on some 35's with wheels...i know they are too much for my b2 but i still want them!!
stickboy697
Iowa
Nice ride for $400! Love the BII's
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
Any ideas.......should i hook the rear sway bar back up?? i was going to use the longer end links on the front sway bar....want to be able to drive it without it having a ton of body roll. will a front be enough??
Harley
2
Oregon
Ford bronco 2
Engine Type
2.9 V6
2.9
2WD / 4WD
Staff online
Shran
April Truck of The Month
