2002 fuel pressure damper location?
MNRANGER2002
2002 4.0 sohc - Just wondering if someone could help me out with the location of the fuel pressure damper?I can't find it anywhere on the passengers side fuel rail. The only place I can't really see is under the ignition coil on the fuel rail, would this be the location of it? Don't really wanna remove it to look under it unless I have to. Thanks in advance.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Look for a vacuum line going under there, pulse damper has a vacuum line attached in case of the leak in it's diaphragm.
You can also look on ebay for your model fuel rails and see where it will be
MNRANGER2002
Thank you Ron.
Staff online
Today's birthdays
Shran
April Truck of The Month
