dangerranger4.0-94
- Dec 8, 2011
- Reaction score
- 0
- Location
- rochester,ny
- Make / Model
- ford
- Engine Size
- 4.0
- Automatic
I'm having a problem with my 94 ranger 4.0 I'm getting code 332 and I've placed everything and tested all the sensors for the right voltages. EGR vacuum regulated(as long as the key is one) always has 14 volts. It doesn't change as the engine is running. The vacuum regulator works when I take the wire for the computer off and ground that side of the sensor. It then activates and the truck stumbles when the EGR valve opens. But when the wire for the computer is reconnected the EGR does nothing. I've tested everything and the only part I haven't replaced is the computer , which I really don't want to.
Parts replaced: EGR Vacuum Regulator
EGR to manifold tube
EGR valve
EGR vacuum hoses
DPFE sensor
DPFE sensor tubes
Sensors tested: EGR vacuum regulator 14.70 volts
DPFE- PCM wire 14.6 volts(tested against a main
power supply)
Sensor wire 1.07 volts(0.9 volts required)
5 volts on 3rd wire(as it should)
EGR valve
EGR vacuum hoses
DPFE sensor
DPFE sensor tubes
power supply)
