Caesar
- Dec 17, 2013
- Reaction score
- 0
- Location
- RI
- Make / Model
- Mazda
- Automatic
So my 98 Mazda B4000 has PATS because one of the previous owners swapped in a 99 4.0L SOHC from an explorer. I confirmed it does have the PCM from the SOHC and not the OHV.
Anyways when I go to start the truck with KOEO the fuel pump runs continuously, and doesn't shut off after the set amount of time. I never let it run like that for very long. I already swapped the fuel pump and tank pressure sensor a few months back because of a P0232 code (Fuel pump secondary voltage high). We have traced all wires, replaced the inertia switch and fuses/relay. The only thing left to try according to the Ford Service Manual is the PCM. I have read that a continuously running fuel pump in a Ford is usually the PCM. On a side note the truck runs and starts just fine, but I am tired of the CEL always being on.
So the issue I have is if I swap the PCM with another my keys/PATS module won't be compatible with the new PCM. I can get a used PCM for a 98-99 Explorer or Mountaineer 4.0L SOHC for pretty cheap, but the issue is getting the dealer to reprogram it. I already called one of the local Ford/Mazda dealers in RI and they said they wouldn't even do it because my truck "contains parts from different vehicles." I asked another local dealer and they told me they don't have/use the NGS system anymore and directed me to the nearby Mazda dealership! I don't even want to ask another dealer because I don't like getting the run around and their condescending responses.
I have read that some locksmiths can reprogram keys for these vehicles, but can they reprogram my existing keys to a new PCM? Is it roughly the same process? I currently have 2 keys for the ignition, and 1 for the doors (likely the original), so I shouldn't need a new cylinder. So what are my options for getting a new PCM to work with my truck? I have considered going to the junkyard and seeing if I can just get the PCM, ignition, at least 1 key, and the PATS module from another truck. But that is a crap shoot, especially finding the key. I am located in RI, if anyone knows a nearby dealer/locksmith that would be willing to help me out that would be great. Any help would be appreciated!
