1990 2.9 pinging
Crash_X
Grass valley, Ca
Hi all,
Ok this is going to take a bit of explaining.
1990 2.9 Ranger 133k miles. very clean.
Previous owner put new injectors in. But siliconed the intake gasket.
I get truck, runs weak but not to bad.
changed fan clutch (frozen), Exhaust gaskets (both sides leaking). This also when I found the dist was crazy loose. cant believe it ran, much less as well as it did.
Go to smog, HC real high, smog guy says look for vac leak.
2 1/2 cans later, I cant find a leak that would make the engine alter.
Go back and with the sniffer in we found the lower intake was leaking.
Change intake (upper and lower), found silicone and one loose forward bolt.
Thinking I found the problem.
Well NOW, I have a pinging /rattling. Sounds like a coffee can of rocks.
Consistently happens at 2400-3000 rpm
At first it sounded so bad it sounded mechanical.
Listened all over the engine and narrowed it to number 5 and 6 cylinders in the valve cover or at the intake valves. Found nothing!!!
Why I think its ping is cause if the spout conn is pulled the noise almost goes away.
Base timing is 10* with spout out.
I have put new cap and rotor, plugs, TFI.
Spout circuit is good, and no codes.
I even retarded the base timing to see if that helped. It didnt.
could it be the PIP unit?
computer is controlling timing when the spout is in.
with a base of 10* timing goes to 25* and is steady in till a throttle blip.
Timing does not change when ping starts happening.
Im dying here guys. Im out of time, money and patience.
Please help me save my little Ford :shok:
Thanks
RonD
Official TRS AI
TRS Technical Advisor
8,369
canada
Welcome to TRS :)
Try 12deg BTDC as base timing
You said you tried "retarding" the spark timing, which means 8deg BTDC which would make octane based pre-detonation worse.
Advancing the spark timing, sparking earlier in the compression stroke, would be 12deg BTDC, so spark occurs earlier before Regular Gasoline can pre-detonate.
That's assuming this is octane based pinging/knocking.
You can run some Premium fuel to see if thats the cause
There is also Lean air:fuel mix pinging, since you get the pinging above 2,500 RPM you could have a fuel pressure issue, fuel pressure is dropping under load.
This could just be a dirty fuel filter, it can't pass enough fuel for higher demand so pressure drops at the engine and fuel mix goes Lean.
I would expect a CEL(check engine light) over time if this was happening.
Then there is heat pinging, it is octane based but caused because a cylinder, or a few, are running hotter than normal, it only takes a few degrees hotter to cause regular gas to pre-detonate.
If you "lug" any gasoline engine it will ping, this is heat based, wrong gear ratio, engine doesn't have the torque so starts to heat up in the cylinders.
Try downshifting, manual or automatic
Octane based pinging generally won't happen until engine is fully warmed up, so test if you get pinging when engine is still cold and you are driving at 2,500-3,000rpm.
Also when engine is pinging, press down on the gas pedal all the way, WOT(wide open throttle)
On the upper intake on the throttle plate is the TPS(throttle position sensor), this tells the computer drivers position on gas pedal.
When computer "sees" WOT it ignores O2 sensors and runs RICH fuel mix for maximum power.
Simple test to see if you have WOT, throttle cables stretch and are easily fixed
Turn on Key
Press gas pedal down to the floor and hold it down
Try to start engine
It should NOT start, it should not fire, it should just crank
Release gas pedal and it will start
This is called "Clear Flooded Engine" and all fuel injection computer have it
Key on = computer on
gas pedal to the floor = 4.5volt on TPS(WOT)
If computer sees WOT and RPMS are at 0 then it will turn off fuel injectors
Clear Flooded engine allows you to dry out a Flooded Engine
So when you crank the engine with Clear Flooded Engine ON, no fuel will be coming in so no start
If engine does start then Google: Ranger throttle cable mod
Stretched throttle cable is not opening throttle plate all the way, so only 4v from TPS and no Clear Flooded Engine
This will also give you more power, since you were not getting full throttle before
Crash_X
Grass valley, Ca
Thank you RonD
so it looks like I wasnt clear on what rpm this happens and that it goes away after 3000 rpm. or that I cant hear it at that point.
I can make it happen no load in the driveway and really seems the same on the road with a load.
So I did check that it does not happen when cold,
and "clear flood" is working.
when driving warmed, it kind of clears up when I do go WOT.
But at that point im passing the RPM range that it makes noise. But it does sound like it would be lean cause WOT seems to clean it up some.
I know the 2.9 has a "rumble" when lugged down.
But I can do this parked in the driveway with no load.
Very manipulatable, always at 2400, stops around 3000-3200.
Not there with spout out or when cold.
I will try advanced and see what that does for it.
I know filter should be changed, just havet got to that yet. and it clears up at upper RPMs but is weak and stops pulling around 4500-5000.
I forgot to say I did a Sea foam on intake (wasnt very dirty inside when I did the intake gasket) and oil treatment ( had a lifter start sticking, but that seems better now).
The CEL does work, but has never come on during this (except when I unplugged the MAF to check if ecm was doing its thing)
Thanks
Im going to go adv timing and see what that does.
Check back later
Crash_X
Grass valley, Ca
Ok, update:
adv base time to 12 then 15.
both lowered the RPM that it started rattling.
And was worse, harder rattle.
12 about 21-2200
15 about 17-1800
warming up at 24-2500 (with spout in), no rattle in till temp started coming up.
started very mild then progressed as temp came up.
What next? LOL :)
RonD
Official TRS AI
8,369
canada
What about 8deg BTDC?
Does it have the same spark plugs in all cylinders?
Have you or could you check the tips on all 6 to see if one or two show a difference from the others?
Do the spark plug wires match?
Like they are a from a matched set
Crash_X
Grass valley, Ca
Hi RonD,
8* didnt really change much that I could tell.
Plugs are new motorcraft I put in.
Wires are a good looking matched set. I will change them out when i get some money for it.
Last time I seen the plugs, they looked great. no diff. that I could tell.
Also, today it sounds like it moved to the other side of the engine.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Just a thought, have you pulled the distributor and checked the integrity of the bottom of it?
Crash_X
Grass valley, Ca
Yes Ive had the dist out a few times.
All felt and looked good as I could tell.
RonD
Official TRS AI
8,369
canada
Could it be valve train noise and not pinging?
And could you run Premium gasoline just to make sure it is ping/knock issue not valve train noise.
Since RPM range changed with spark advance I am sure it is pinging but.................I've been sure about a lot of stuff that was just plain WRONG :)
dirtymike
112
knoxville TN
Ranger lwb
Engine Type
2.9 V6
2WD / 4WD
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
maybe hydraulic lifters not building up. oil circulation. Whats the oil pressure.
lvwill
143
Las Vegas Nv.
ford
Engine Type
2.3 EcoBoost
2.3 Ecoboost
2WD / 4WD
2WD
I'm actually having the exact same problem but haven't had a chance to look into it yet. Seems to run fine with the spout removed, just down on power.
Crash_X
Grass valley, Ca
I have real good oil pressure.
Not sure how the spout conn would affect lifter noise.
Would be nice if thats what it is, But I dont think so.
But I also have been wrong many times before.
RonD
Official TRS AI
8,369
canada
With SPOUT connector removed there is only centrifugal spark advance done by the TFI Module, so RPM only spark advance
SPOUT(SPark OUT) is the spark advance from the computer to the TFI module, it takes the place of Vacuum Advance used in older distributors.
Vacuum Advance or SPOUT changes spark timing according to engine load.\
Without SPOUT spark timing is only changed as RPM increases(or decreases), so is slow to react and will be as described, "sluggish" performance
If engine stops pinging when SPOUT is disabled then Base timing is wrong....or computer is miscalculating engine load, either because computer has a problem or its sensors do.
There are only two sensors used to calculate engine Load, air flow and Throttle position
There were two kinds of air flow sensors used on Rangers
MAP sensor measured intake manifold vacuum level
MAF sensor measured air flow into the intake
Throttle Position Sensor(TPS) gives computer the 'heads up' that driver wants to speed up or slow down, so it can instantly increase or decrease fuel flowing into intake.
Computer has a table that it uses to calculate engine load based on throttle position and air flow.
When an engine is under a load air flow is less for that throttle position that if it was under no load.
That's why vacuum in the intake drops, more air is available than the engine can use as the throttle plate opens.
High vacuum is when there is less air than engine can use, throttle plate closed, so engine is trying to pull in more air than available.
Difference between throttle position and air flow is the engine load and computer sends that spark advance to the TFI module
The higher the engine load the more the SPOUT is used, at lighter load only TFI's centrifugal(RPM Based) spark advance is being used
Crash_X
Grass valley, Ca
RonD,
To my understanding I do not have mech adv.
I read that there is nothing but the control by ecm.
I have matched piston to crank marker. Its right on.
Really feeling I have proper base timing.
Ok, just got some other input from friend.
I retarded base time to about 10* ATDC.
spout in, goes to 4* BTDC
Almost all noise goes away. but can still tell its there.
going for a drive in a min to see.
Thinking ECM might be the issue.
I have a TPS to swap for test, but I dont have another MAF.
I am wondering why I have a factory MAP mounted 'in' the firewall but no wiring conn. and looks like its never been used. could this be a left over from factory changing over to a MAF?
Thanks for the text book info.
I am a sort of seasoned mech. (40 years) ( but still screw up often) and thats why this one is really odd. I have seen alot of shit over the years, but this one is really out there. LOL.
Being I just bought this truck, I feel I would have heard this noise when I inspected it. I noticed it after changing intake gaskets. But have no idea what I could have done to cause this. Thinking I had to have missed it and it was always there.
More info to follow :shok::icon_rofl:
Thanks for all the help :)
Crash_X
Grass valley, Ca
And for the next chapter,,,,
So with no doubt it wouldnt move its self at 4* w/ spout.
Set base at 10* and went up the road. (with spout).
so any where in the 1800 to 3000 rpm range I can hear it. (yes its lower then before).
I can affect it by how much throttle is applied.
Light to mid throttle it rattles,
push in a little and it goes away.
the higher the Rpms, the more pedal it takes to make it go away.
Also, any where in this rattle range, WOT will make it go away almost all the way.
Also any Deceleration it goes away.
I can 'play' with it in that rpm range, as in, in and out of throttle, light and heavy load, WOT, full decel.
All of these affects the volume and severity of the rattle.
WOT feels real good for a 2.9.
Because of the effects of 'on and off' the throttle, I feel its a lean thing. But I cant see what the timing is doing during these times on the road, in the driveway with no load, the markes move when throttle is moved, but stay very steady other wise. Even when the tin can of rocks come in to play, Steady!
IF, I am lean, could the injectors the previous owner put in, be wrong?
Could TPS be flakey? Changing it out with one in a few min.
Thanks, see ya next chapter :)
Members online
Today's birthdays
Shran
April Truck of The Month
