Caesar
- Dec 17, 2013
- Reaction score
- 0
- Location
- RI
- Make / Model
- Mazda
- Automatic
I have a 98 Mazda B4000 with a 99 4.0L SOHC Explorer engine that was swapped by one of the two previous owners. I have become pretty proficient at doing some sensor rewiring and reading/intrepreting both vehicle wiring diagrams, but the fuel pump has me stumped. The fuel pump runs continuously with the KOEO, and if left that way for more than 5-6 seconds without starting the vehicle it will throw a pending P0232. It also runs without the relay and with the inertia switch unplugged. Before anyone suggests anything I finally figured out why, and after already having swapped my ECU, lock cylinder, and both PATS modules thinking it was the computer. Fortunately those items only ran me $45 at the local Pick n Pull. The newer computer is for a 99 SOHC while the original was for a 2000, so it actually shifts a bit better/more precise shift points.
I discovered that the previous owner had jumped the relay by feeding a 12V wire (hot while run and start only) a little after the inertia switch in the drivers side kick panel. The pump actually works like this and maintains good pressure, it just stays on (and throws a code) if the key is left in the ignition for too long without starting the truck. I have installed a kill switch on that 12V line so I can work on the truck with the KOEO and not have the pump run continuously. I have recently passed my state inspection with it like this, but I want to fix it in the long term.
What I have figured out so far is all of the wires connected to the relay have good continuity and resistance, but I have only visually inspected the grounds. I started tracing the voltage from the relay to the inertia switch and pump and the voltage always reads 12V for a second and then drops to 7V after the relay when the key is engaged (but not started). I am having trouble figuring out why the voltage is dropping. Two pins on the relay read 12V, one hot at all times (from fuse 9) and the other red wire (hot in run or start). The green/yellow wire leading to the computer (pin 15) and inertia switch only reads 7V after turning the key. The pump will not start/run with only 7V. The blue/orange wire coming from pin 80 reads only 0.03V directly at the ECU and at the relay. I am not sure what voltage this wire is supposed to read with KOEO, and I would suspect that this is possibly one of the culprits. Any suggestions on what to do/check next? I would greatly appreciate it seeing that electrical is not my strength. Fortunately my truck runs and drives great, but knowing that the fuel pump is not controlled by the relay (and inertia switch) is a bit unsettling.
