Bronco 2 motor ?
mr262bronco2
is the 2.9L in a 1988 Ford Ranger 5 speed 4x4 the same as my 1990 Ford Bronco 2 4x4 automatic
1986fordranger
central VT
ford
2.3l/4.0l
it is, how ever the engine wiring harness will be abit different, so you will need to swap it over to the other engine
mr262bronco2
what part of the harness is different ? do I absoulutly need to swap harness with motor ?
1986fordranger
central VT
ford
2.3l/4.0l
IIRC the main plug connection below the brake master cylinder connect's the under hood wiring (EFI wiring, ignition wiring, headlight's ect) to the interior wiring, (PCM, gauge's, ect), on the older 1988 it should have a different shaped plug then that of the 89+ plug, the easiest way is just unplug the wiring harness from the fuel injector's, sensor's, ect on the engine and just swing the harness up out of the way and do the same with the donor vehicle
mr262bronco2
this will be my first motor swap ever. I have other things I would to do such as lift and brush guard front bumper and brush guard tail light covers and if I can find a light bar for a nice pair of kc lights. its a clean bronco and the guy I got it from put a lot of work into it so that's why I have no problem swapping motors. after swapping the motors ill be looking to part out my 1988 ranger. 5 speed , 4x4 . or if someone does my motor swap ill give them the ranger. lol
mr262bronco2
my problem is time and tools and money til I get back to working again. I have even thought about selling the two vehicales together but I have always wanted a nice bronco 2 having 3 kids and a wife my free time is very limited
kenncarl
ford
Where are you located..??
PetesPonies
25
east coast
Ranger
2.3l
The engine is the same.
Slammin Sam
4
Western Colorado
2.9
The 89 and 90 2.9 had an improved stronger head design to help alleviate the cracking problems. This won't effect putting an 88 engine in a 90 B2. If the heads are good on your 90 engine, you may want to pull and save them after the motor is out.
richard booth
28
Tacoma wa
ford
2.9 for now.
Much wisdom in that keep the heads suggestion.
Darknight
Just the strength of the heads on the engine. The harness will be the same, you might have to splice a couple wires. Which isn't to difficult.
Sent from my ONE TOUCH 6012A using Tapatalk
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
