Ranger 8.8 31 spline swap with stock housing
thcscubajohn
31
Antarctica
FORD
Engine Type
247ci
2WD / 4WD
4"
31x10.50r15
Smog is for pussies.
Does anybody know where I can get 31 spline axles for a 94 ranger and what bearings I will need if I keep the 28 spline axle housing. I am going to load it up with 4.10s and a torsen lsd
Sent from my SM-G950U using Tapatalk
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
search for "a31-rang" a couple of threads have the info you need
thcscubajohn
31
Antarctica
FORD
Engine Type
247ci
2WD / 4WD
4"
31x10.50r15
Will do
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
oops, my bad. "a31-93rang" will work
thcscubajohn
31
Antarctica
FORD
Engine Type
247ci
2WD / 4WD
4"
31x10.50r15
Ah I was gonna say
thcscubajohn
31
Antarctica
FORD
Engine Type
247ci
2WD / 4WD
4"
31x10.50r15
Doesn't really tell me where to get them I want them new and if I look for replacement shafts for an 02 they're all 28spl do you think Richmond will make em for me
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
just checked Jegs.com $260 for a pair of Moser shafts, shipping in a week.
they have full details & specs. I would think numerous vendors sell these.
thcscubajohn
31
Antarctica
FORD
Engine Type
247ci
2WD / 4WD
4"
31x10.50r15
You got a link?
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
jegs.com search for the a31-93rang part number
summitracing.com is another vendor
thcscubajohn
31
Antarctica
FORD
Engine Type
247ci
2WD / 4WD
4"
31x10.50r15
You don't know anyone that can make a manual replacement for the M5OD-R1 that can handle 600 ftlbs?
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
I think your pretty much looking at a ZF at that point.
thcscubajohn
31
Antarctica
FORD
Engine Type
247ci
2WD / 4WD
4"
31x10.50r15
Captain Ledd
39
Michigan
302, 2.3
Freidrichshafen?
Anyways, A Ford/GM-truck ZF of various flavors, or a medium duty truck transmission is your best bet for dealing with 600+ lb ft.
thcscubajohn
31
Antarctica
FORD
Engine Type
247ci
2WD / 4WD
4"
31x10.50r15
When I look up ZF transmissions I find ZF freidrichshafen realistically I'm only looking at about 500ftlbs but reliability is the key of this build and the R1 is only rated to 331 ft lbs I want a manual 5 or 6 speed replacement I can find automatics all day long but have had no luck finding a company that makes manuals
Staff online
Shran
April Truck of The Month
