86 Bronco II wont say running HELP
vwbug1957
ford
When i start it cold the vehicle runs great then when its warms up it will die and cant get it started again The fuel pumps where replaced before i got the vehicle it. I replaced the TFI ingination module. Any other ideals?
Thanks Mark
Junkyardexpress
ASE Certified Tech
Ellsworth,Maine
Engine Type
2.9 V6
2.9L
2WD / 4WD
P235/R15
is it a 2.9 and what does it do when you try to restart it?
vwbug1957
ford
Its a 2.9 with stick, After its quits it just turn over but will restart 1 hour later.
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
My sister's Ranger di the same thing only it was a 4.0...never did fix it. I have seen vehicles do this due to bad injectors. Whenever it warmed up,the resistance in the injectors went up so much that they just didn't work anymore. When they cooled down again it would run. .....but that was a C4 Vette :icon_confused:
Junkyardexpress
ASE Certified Tech
Ellsworth,Maine
Engine Type
2.9 V6
2.9L
2WD / 4WD
P235/R15
try a fuel relay they cheap it's under the fuse box on the right inner fender if it's the same as mine
Staff online
Shran
April Truck of The Month
