1986 bronco 2 lift on budget
mwicks5812
ford
I've seen on here that f150coils can be used to lift,
is there a particular year to use for this???
ford
4.0
that would be cool. im betting on a newer, like 04 and up because they were taller and had to have a tall spring due to bigger tires out of the factory.
1996xlt
23
NC
IIRC they should be from an F150 of similar vintage to your bronco, as long as it has a TTB front suspension. I've also heard that 91-94 Explorer front springs work.
swynx
9
lewiston idaho
Mazda
4.0
its a similiar year f150, itll be a bumpy ride as the springs are stiffer; more ppi for the bigger truck and engine. a lot of people use explorer front springs, as they are stiffer but not a a lot stiffer. you could also try jeep coils, a lot of people have great results with jeep coils, but they are soft so some fine tuning will be needed. or skyjacker 132x coils, will give around 2 inchs lift.
a lot of info on this in the tech section, or you could always use washers. whatever you do youll need some different alignment bushings, of about 4*
Staff online
Shran
April Truck of The Month
