sway bar bushing
chrwilkins30
6
Mishawaka, Indiana
I'm installing new bushings in the front sway bar. On summit it says there is to different sizes. Does anyone know the size?
Nathan123
Millersburg Pennsylvania
2.9 Litre
I just changed mine out two weedends ago, got mine from james duff and ordered the ones that say 1" dia., 3.5" tall. http://www.jamesduff.com/broncoII/bodylifts.html
The original ones however, were only about 1.5" of rubber that sat on a stamped steel seat, or spacer. The replacement was solid poly and fit right in.
Well, the size you need will depend greatly on the size that is on your truck already.
Nathan123
2.9 Litre
Yeah I just noticed you have an '88 mine is a '89 and duff specifies '89+ so you definitley have to measure yours, both the diameter of the sway bar and the height of the block. Makes a huge difference in cornering though if the old ones were shot, definitely worth it.
