Newbie from NJ 1990 Bronco II
jules82
I just got a 1990 Bronco II to bring back to life. I live in Ringoes NJ bought it for $500.00 so far I replaced valve gas,starter, battery, rear drive shaft, plugs, oil and belts. It has 180000 miles with a valve tap not worried I have a 4.0 to drop in lol. I need to replace brake lines does all Bronco II come with ABS ? I want to order them from inline tube in SS I need to know. I have a 82 t-top GT Mustang turbo 5.0, 79 CJ-7, 99 dodge ram 2500 Cummings, and a 2012 WRX for my other rides. The Bronco my son will drive in winter at college then summer I'll play with it no cancer on it thanks
Sent from my iPhone
deathbypsi
06/2012 STOTM Winner
MTOTM Winner
79
Mich
ford
2.3turbo
Wow looks clean!!
jules82
Thanks it's worth the $ I'm putting into it the last owner put shocks exhaust and a lot more. No rust very clean in and out I need too find a matching rim that's about it after brakes
Sent from my iPhone
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Very nice. What is the build date on it. If its after 10/89. Awesome find. It'll have the D35 in it. Is it manual or auto?
jules82
5 speed? On the knob it says 4 then od for 5 th ? I will check the door but the vin# is 1FMCU14T9LUA28240 if some knows how to read that it would be great lol. I know Mustangs but not Broncos I'm looking for a wire harness and computer so I can put the 4.0 in. The engine has 50000 miles came out of a 94 Ranger 5 speed
Sent from my iPhone
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Let me explain something very carefully since it seems to be a hard to grasp concept. No just for you Jules, for everyone. The selected portion of your post just helps make my point clear.
Over drive is a speed gear. That mean if you have a "4 speed with overdrive" you have 4 different forward gear ratios, one of them is greater than 1:1.
If you have a shifter that says 1,2,3,4,OD that is a "5 speed" transmission.
jules82
I know that but I was thinking it was the Mazda trans my Mustangs have top loaders 4 speed or tremec trans T-5 I'm in the learning with the bronco II I know Jeeps I have 3 79 CJ -7, 88 Comanche and a 89 wrangler. The CJ has a 1969 boss 302 t-19 trans Dana 300 twin stick I built from ground up. From the pic I have barn lift etc I'm not stupid lol just bought a 03 Explorer today blown 4.0 I'm a dealer too buy sell fix etc 47 years old been around block
Sent from my iPhone
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
We just have a lot of noobs who can't seem to grasp the difference.
jules82
Thanks when I ordered the driveshaft for the rear they had 3 lengths on was 4 speed od, 5 speed and 4 speed mine was 33 inch
Sent from my iPhone
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Look for the trans code on the door. It should Have an M for the mazda tranny.
jules82
Thanks just want some info and some meets etc. To learn more my mooto is you stop learning when you are 6' under lol
Sent from my iPhone
jules82
I'm doing my 4.0 swap right now lol I read up did research I'm using a 94 ranger engine that has injector and alt wiring on it complete. The ECM and harness is from a 92 4x4 5 speed Explorer 4.0 flywheel clutch and starter with a new 2.9 slave. I can't marry the engine and trans? Should I be using a 4.0 slave? And will this wire combo work? There is a square red plug about 1" 1/2 on the main harness didn't know where it goes? Need help please thanks
Sent from my iPhone
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
Still need to post a pic of that wiring plug in.. Where on the harness is it? Close to what other plugs?
Protowrxs
Shawnee,OK
2.9 - 4.0 Waiting
If the big square plug is on the 92 Explorer computer harness, it should match up with the '92 Explorer Engine harness. That has nearly all the sensor and actuator connections for the computer in it.
Honestly in my humble opinion, it may be easier to use the '92 Explorer Engine harness. Otherwise you are going to have to match up the wiring differences, whatever they are, between the two harnesses.
My '93 Explorer engine has additional Cam Position sensors and O2 sensors that the '92 did not have so there are additional / different connections. Thus I am using the '92 engine and computer harness which lowers the re-pinning/re-wiring.
Just saying...
All this is going into a '89 Ranger however, but should be very close to your '90 BII.
But post up pics and info as you get it figured out.
Staff online
Shran
April Truck of The Month
