87steelhorseII
- Oct 7, 2013
- Reaction score
- 0
- Make / Model
- Bronco II
- Automatic
This seller has a limited supply of clear tail lights for purchase (12-15?). I found this seller while searching ebay and purchased a set, only mine does not have the red bulb like in the attached picture, which I plan to use a red LED bulb for mine. My set is trimmed in silver.
If you dont like the red bulb casing, seller indicated that some have broken this casing to use their own type of bulb. The lights are a product of mexico and are not like your higher end aftermarket lights. My set has a bit of yellowing where the screw holes are located, but unless you look, you would never notice.
While looking for a set of clear side marker lights, I went back to this seller and he checked with his supplier who only had a few of those sets left but are now all gone and the supplier no longer plans to make any more. His supplier then located the tail lights in the warehouse and sent them to him. Once these are sold, there will be no more. http://aftparts.com/?page_id=21
If want to email the seller for any questions, contact James at <info@memoimports.com>;
